New Garmin Synching issues
I noticed the same here now…
A few days back it worked like it always has, but not now. Zwift has changed something with the sync I guess or Connect has changed something but as you say it works outside with Edge computer and it does inside to when I do dual recording so the problem is data from Zwift…
Is it a comma vs a period issue?
From reddit
Who is it that you’re quoting (someone from Zwift, Garmin, somewhere else)?
It’s @Jon (Zwift)
I wonder if the fix will retroactively correct the bad data in third party services. I’m guessing not. Bring a mop.
Is it an issue with the FIT file itself, so even the FIT files available from Zwift won’t be retroactively corrected? I’m holding off downloading any FITs for now.
You can use the “Section Remover” option from https://www.fitfiletools.com/ and don’t remove anything, just click “Go”, download the resulting file and upload to Garmin.
Edit: no, sorry, doesn’t work well, it created wrong elevation data for me.
Tried Cookbook | FIT SDK | Garmin Developers and it also messes the elevation data.
Best result I got was using the crop option in Garmin Connect website, still changes the elevation but not so much
Facing the same problem
Same issue with Kickr Bike Shift. Garmin Connect rides show “–” in the speed field. The fact that multiple makes of smart bikes are experiencing this bug makes me think it’s definitely a Zwift issue.
As a bit of an experiment, I manually downloaded a FIT file from a Zwift activity. Manually uploaded this into Garmin Connect. My Garmin Connect in turn is synced to Strava. The Garmin Connect Activity is all messed up, however the Strava activity looks fine even though it was sent there by Garmin using the same file.
Same problems here …:sleepy:
When I export my zwift ride into garmin connect, it seems some items are updating like Watt, heart rate, acute load but it seems my training readiness and recovery time is not updated. Does anyone know what I should do in order to have also these 2 items updated?
Read the pinned post about it
Same issue here 55.1 km ride logged as 55,170.11 mi
Hey everyone - We released a patch to fix the issue with activity uploads. 1.77.2 is now available for Mac / PC / Android / iOS. We will release game version 1.77.2 to Apple TV as soon as Apple review is complete.
Not 100% sure about training readiness, but some training metrics don’t get updated by just uploading to garmin connect. These training metrics, e.g. training load are calculated on a Garmin device only and hence after uploading an activity from Zwift to garmin connect the device needs to be synchronised, the device will then calculate the training metrics and then after another sync (ma be a minute later) you will see the updated training metric in Garmin connect as well. At least that works for me with training load. You could try whether training readiness works the same and share your findings here.
Best regards,
Magnus
Like I said, training load is calculated and synced but unfortunately this is not the case for training readiness and recovery time.
@ Paul ,
you have a link plse as there are so many pinned posts
Hey got the update & it is working again.
Also is there a fix for the incorrect fit file that has already synced?
