6 posts were split to a new topic: Zwift Companion can’t add Garmin Connect service [December 2021] [v3.29]
Hi, worked perdect this evening. All good
Just finished two rides on Zwift. Both popped up in GarminConnect very quick. Today
OK - thanks for the reply - made me check my connections and realise I’m still connected to Training Peaks even though I don’t use it anymore - will turn that off.
Cheers, J.
Same problem here.
First issue was on Nov. 15th. Today I Zwifted again, same problem Zwift doesn’t sync with Garmin. (yes with my others).
Furthermore, I downloaded the today activity from Zwift and when I try to upload manually to Garmin…fails. Only I could get upload it if previously I fix the fit file with fittools for modify the timestamp.
Adding some info:
I disconnected Zwift from Garmin figuring that maybe reconnecting would sole the problem. Now I can’t reconnect. When I try to add the connection, the pop-up flashes and goes away.
Hello @George_Koefler welcome to Zwift forums.
Are you having this problem when using the Companion app? Someone else brought this to our attention and we are working on fixing it. Please join this dedicated thread where we’ll update progress toward a fix.
hello @shooj
As you are working on this topic, i would like to share with you somthing
As competitor on zwift, i use a lot of time Dual Record, with this practice i have 2 issues
1 - Dual record is not automaticaly sent from Garmin to Zwift Power. It will be good if someone can work on this topic. (maybe by adding another Bluthoth connection for bike computer on ZWIFT)
2- I don’t synchronize Garmin accunt to Zwift because we got 2 session if we use dual record. (by working on 1, we can propably solve this issue at the same time making priority on GARMING or Zwift activitys)
thanks for reading
Ride ON
So just another update both the wife and I did a zwift workout last night and her activity instantly went to Garmin connect from zwift but mine did not I had to manually transfer my zwift activity to GC both operating systems ATV4K
About 1 out 4 Zwift activties are uploading to Garmin Connect… can’t see a pattern or trend. Sometimes an activity loads right away, sometimes a few hours later, but lately, mostly not at all. When I’ve done more than one Zwift in a day - always back to back - sometimes one uploads, sometimes neither. Like I said I can’t see any pattern.
I can import the FIT files myself but that’s a major pain to be honest.
I tried to disconnect in Companion app, and then Connect again. Now I can’t Connect at all in Companion ![]()
Try the website as mentioned above.
Not sure what’s changed… but I did 4 separate activities yesterday and they all uploaded to Garmin Connect immediately. First time in about 2 weeks that’s happened. Hopefully everything is fixed ![]()
Neither my runs or rides have been uploading to Garmin since Dec 05 2021
In addition post the activity, the activity is being removed from my Garmin connect calendar, populated by training peaks
Zwift activities are loading to Strava and Training peaks
Have tried disconnecting and reconnecting a few times, no change
Same issue. Any update on this? MapMyRun and Strava work just fine with sync and upload.
Best regards,
Drew
Still the same intermittent issues. Training eaks and strava work perfectly. When zwift activities are uploaded to garmin manually they atre corrupted. It’s tedious manually uploading or using a fit file fixer. Seriously considering cancelling my membership and doing them in an app thst works properly.
Is there something I have to do to manually add the .fit file to Garmin Connect? I always get an error message.
Pretty frustrating.
I can’s set and connect from zwift companion to Garmin App… days ago disconnect theirself and i couden´t connect again. What thing i´ll need to do?
Having the same issue. Rides on Dec 10 and 12 not uploading the GC using Apple TV 4K. Ride saves ok in Zwift and showing in Companion app.
I am also having issue where on companion app and PC and AT when I select Garmin in Connections it flashes then disappears before I can do anything. When I finish a ride in Zwift it only shows upload to Zwift now not Garmin as well like it used to
@shooj Any chance of updating us with this issue? This has been persistent since the start if December, so far we’ve got radio silence from Zwift. You noted the issue 8 days ago and it seems like everybody else is still experiencing it.
This seems to be a zwift issue rather than a garmin problem, as all the activities that don’t sync from zwift seem to be corrupted when uploaded to garmin, whereas some of them are absolutely fine?
