At this time, the launcher app will not update itself. We are planning to auto-update to Launcher app v1.1.3 with the June 2022 Zwift game update v 1.26
Update April 21:
We made a minor change this morning and rolled out PC launcher v1.1.4. It contains some code specific to Windows 11 so you don’t need to reboot after installation
Sorry if i’m being simple here… but in order to resolve the launcher issue i would need to reinstall the entire game?
Following the links provided takes you to pages that detail a complete reinstall. That’s a little different than “Zwift Launcher v1.1.3 for PC is available for manual installation.”
No. When you download and run the installer, it basically only installs the launcher and its associated dependencies. Then when you run the new launcher, if your game is already up to date, it won’t do anything else.
With 1.1.2, many more people ran into the annoying pauses during the download & installation phase than the handful of people who still had the white screen issue, but you’re not wrong.
For what it’s worth, the easiest way to update on W10 and newer is winget.
winget upgrade --all
will update all packages that you have installed, and Zwift Launcher 1.1.3 is already in the repo. Do that routinely and you can have everything from VC redists to 7-Zip to Zwift updated.
I had a feeling that might work too but wasn’t at my home PC to test it. But yes that’s even easier.
As an FYI, you can also just do “winget upgrade” and it’ll show you the list of packages it has updates available for without making any actual updates.
Very little else installed on my Zwift PC, so it’s not something I’ll need routinely but I’m always happy to learn something that saves clicks. Cheers!
