It seems like Deutsche Telekom has an issue with routing into a huge network assigned to AWS (Amazon Web Service) where e.g. Zwift is running its authentication service (or using a provider who is hosting within aws). The affected network is 52.93.0.0/16. I’d urge anyone who has problems to open a support ticket with his ISP so they can properly work on it.
Here is an example to trace the way to secure.zwift.com which is the service you have to logon:
➜ ~ traceroute secure.zwift.com
traceroute: Warning: secure.zwift.com has multiple addresses; using 54.149.44.59
traceroute to secure.zwift.com (54.149.44.59), 64 hops max, 52 byte packets
1 192.168.5.1 (192.168.5.1) 5.293 ms 2.460 ms 1.246 ms
2 62.155.221.39 (62.155.221.39) 10.700 ms 11.340 ms 10.172 ms
3 d-ed5-i.d.de.net.dtag.de (62.154.43.126) 20.516 ms 21.007 ms 21.535 ms
4 80.157.204.58 (80.157.204.58) 73.023 ms 73.598 ms 73.638 ms
5 ae10.cr4-lax2.ip4.gtt.net (89.149.130.90) 216.359 ms 215.597 ms 225.998 ms
6 a100-gw.ip4.gtt.net (173.205.58.58) 219.475 ms 218.363 ms 221.056 ms
7 54.239.103.78 (54.239.103.78) 228.656 ms
54.239.103.18 (54.239.103.18) 222.601 ms
54.239.103.42 (54.239.103.42) 219.087 ms
8 54.239.103.73 (54.239.103.73) 220.116 ms
54.239.102.225 (54.239.102.225) 219.879 ms
54.239.103.107 (54.239.103.107) 231.643 ms
9 * * *
10 54.239.44.22 (54.239.44.22) 244.867 ms 242.077 ms 240.757 ms
11 * * *
12 52.93.14.50 (52.93.14.50) 254.292 ms
52.93.15.48 (52.93.15.48) 242.860 ms
52.93.14.124 (52.93.14.124) 249.517 ms
13 * 52.93.15.31 (52.93.15.31) 280.418 ms
52.93.14.35 (52.93.14.35) 247.976 ms
14 52.93.14.68 (52.93.14.68) 245.354 ms
52.93.14.216 (52.93.14.216) 244.478 ms *
15 52.93.246.175 (52.93.246.175) 242.975 ms
52.93.15.25 (52.93.15.25) 237.497 ms
52.93.15.19 (52.93.15.19) 246.470 ms
16 205.251.232.222 (205.251.232.222) 238.671 ms
52.93.246.77 (52.93.246.77) 239.311 ms
52.93.246.75 (52.93.246.75) 240.879 ms
17 * * *
18 * 52.93.240.65 (52.93.240.65) 244.565 ms *
19 * * *
20 * * *
21 * * *
22 * * *
There is no chance to explain that problem to a normal hotline worker there, sorry. The will only perform a quick check that will pass all tests. (There is no, correct but they have to check their own routes to aws.)
We need a tech Insider or big customer which tells them (not the support phone) this problem.
I guess not for a “normal” user. If you use a router with OpenWrt, a Fritzbox or e.g. a pfSense firewall/router you can route your whole outgoing internet traffic via VPN. An easier way would be to connect your ATV with a free Freifunk WLAN hotspot, if you have one nearby - I am running such a Freifunk hotspot by my own, so that’s the way I go and it works. I have to say that it depends on how the regional Freifunk network is connected to the backbone.
Of course you can also connect ATV to the WLAN hotspot of your smartphone, as many people here in the forum have described already - but it can become pricey
Having the same issue
I just canceled my Zwift membership due to that. Maybe time to give TrainerRoad a try.
Any suggestions for a (ideally free) tool to use workouts from TrainingPeaks to control the trainer?
Hi, I have the same problem also since Wednesday last week. Can’t open zwift on my pc nor the companion app on my phone. Initially this occurred only on my Telekom ADSl line but since today also on my Telekom 4G subscription phone. Am typing this now while logged into to the wifi Hotspot on my corporate vodafone phone otherwise I could not login to the forum! So its definitely a telekom issue.
Zwift ist jetzt komplett tot. Es bleibt wohl nur noch die Kündigung. Ich gebe meinem Vertrag noch bis nächste Woche. Dann ist Schluss. Gestern das erste Rennen auf RGT gemacht. Funktioniert und ist kostenlos. Dort sind jetzt mehr und mehr Fahrer unterwegs. Als nächstes mache ich dort auch mal eine Gruppenfahrt mit. Wir werden einfach von irgendwas geblockt. Wer Schuld ist, keine Ahnung. Nur ist ein Abo für einen nicht nutzbaren Dienst sicherlich überflüssig. Das ganze macht mich auch noch zusätzlich zur Pandemie verrückt. Nächst Woche Sonne draußen .
