Another addition to the piles of people having similar issues here.
I have the most recent version of Zwift on my Macbook Pro and use the most recent version of the Companion app for iPhone XS. The Macbook Pro is an early 2015 model and on Catalina (not on Big Sur), but was running fine until around mid way through last year (there are only issues with my HR monitor).
My setup is:
- Wahoo Kickr 2018
- Wahoo Tickr heart rate monitor (most recent version)
- Lifeline Ant + USB (new)
- Favero Assioma Duo powermeter pedals
For a number of months, I have been unable to get a reading with my heart rate monitor and the pairing screen of the Zwift app for my Macbook Pro either reads zero or “No Signal” when I try to pair. Here, this is the case with both BT and ANT+.
In fact, I have purchased a new heart rate monitor and a new ANT + USB stick to try to resolve the issue. This has not made a difference.
For clarity, the heart rate monitor works when paired with the Zwift app for iPhone and with my Wahoo Elemnt Bolt cycle computer. As such, this is clearly not an issue with the heart rate monitor and, given I have just purchased a new ANT+ USB dongle, it does not seem to be an issue with that.
Separately, when using Zwift on my Macbook Pro, I use the Companion app on my iPhone to “control” and chat, etc.
Based on feedback from Zwift, I took the following steps:
- Uninstalled and reinstalled Zwift for Macbook Pro (following guidance on Zwift’s site) and the Companion app for iPhone.
This did not work and the same “No Signal” comes up on the MacBook.
- Checked for issues with signal as per the article you linked. Here: (i) the fan wasn’t on; (ii) no physical barrier; (iii) removed all other computer hardware and BT devices from room; (iv) no microwave, etc. in the same room or being used in the house; (v) no issues with the wifi router; and (vi) no other devices or cables that would interfere.
For clarity, this was not a problem before when in the same room and using the same equipment. There is not an issue with either BT or ANT+ on my Kickr 2018, Favero Assioma power pedals, or any other devices I may wish to connect to my MacBook.
Separately, I noticed another issue that ERG mode does not appear to work correctly when I leave the HR monitor connected in “No Signal” mode (I tested this today and ERG would not activate on the Kickr until I unpaired the HR monitor).
Any ideas anyone?!
