The November ‘fix’ where the system would remember which club a ride or run was last saved to and default to that for the next ride or run is broken for Zwift Run. Instead for Zwift Run the system offers the first club on the list (at least for me).
I realize that as with anything having to do with Zwift Run I’m likely shouting into the wind, but I live in hope.
Ride used to also revert to no club.
As I posted above, now it chooses {a} club. Regardless of whether or not you chose that club before.
So, I think the behavior of the new change has applied equally to riding and running.
Club setting does NOT remember the No Club choice after its changed from a specific Club to No Club. Its annoying as have to set No Club after every ride.
Yep. Just noticed that and for me, that might create hard feelings. I didn’t catch it in time. This really!!! Needs to be fixed. Just set it to no club by default and let the person decide if they want to share each time.
Now, how do I undo that share before someone notices?
To complement the story, on my side I’m in running clubs, riding clubs, and both clubs. Riding would remember last club of the next thing I do is riding again. If I switch to running, it obviously doesn’t show me riding clubs. So I select a club available in running, or let’s say which has both riding and running. Then next thing I do is riding, and last club per default is the one that has running and riding, instead of the previous one that I used in riding.
Last club should be 2 separate entities, one for running and one for riding.
For extra coolness, make it available in companion, because too often I would click save on my phone without looking at my computer screen displaying the wrong club because I expected it to be remembered…
No only does it default to the last club selected, but just now I changed it to “No Club”, sorted out the picture I had to upload and by the time I had finished doing that, it had changed it back to the last club without me noticing - and so saved it to a club even though I had specifically selected “No Club”.
@shooj - can you confirm that this is being investigated as I haven’t seen any recognition from Zwift of this issue?
My 2 ct. I don’t mind it defaulting to last (actual) club selected. However if its initially set to or changed to No Club, then No Club has to become the next default.
