Game Update 1.72 [August 2024]
I have the new version (1.72) on MacOS and 5 min ago I wanted to start riding a "Muir and the Mountain” route in Watopia. When loading I got the following screen and it stuck at it:
In Companion App I can see the view with the map as if the route was successfully loaded and I could start riding. It also the very first time I see broken loading screen.
Which model of mac and version of macOS are you using?
@shooj Still receiving the Vulcan Assertion Error once when Zwift runs for about a little more than an hour.
@Mike_Medwed
We’re investigating that one.
Hi @MateuszK
Shuji at Zwift HQ here. Thanks for attaching the screenshot of the banded launcher screen. A couple of things I noticed when I scanned through your server logs.
  1. Your Mac is running an older version of the Zwift Launcher app. To get that on parity with the latest - please perform a complete uninstall to remove all Zwift-related files from your computer. Instructions are here which are more throrough than the usual macOS uninstall procedure. Please also move any custom workout files out of harm’s way if you have any.
    Then download the latest bundle including the launcher app here.
  2. Would you verify which version of macOS is installed on that macbook? Is it macOS Sonoma 14.0? Are you able to update the OS to a newer version, possibly with an updated graphics driver for your AMD Radeon Pro 5300M?
I have already the newest MacOS Sonoma (14.6.1) version installed and I run on Intel UHD Graphics 630 1536 MB. I have restarted Zwift app and then it loaded the route without any problems.
It’s been a problem for a long while on Zwift. Consistent issue for me on both Kickr v1 and Tacx Neo OG. I don’t use erg mode on Zwift because of it. That reminds me I need to dual record a session with my pm pedals and compare
Itz longer and greater elevation, but Itza Party is showing as less effort and time than Itza Climb Finish. Is that correct?
Apple TV in free ride mode after Neokeyo crit race. The workout screen (in red) appeared to the left side of my avatar and continually appeared and disappeared.
That’s not the workout screen. It’s an indicator that you’ve steered as far to one side as you can go. It was introduced in 1.69.
Thanks Steve, odd as it was not showing up during the race, and my steering was central. I’ll try and recalibrate.
Unsure if anything has changed in the last patch cycle.
But it seems my “connection disconnected” that started back at the end of June every 10 or so minutes either isn’t happening anymore, or is happening at a drastically reduced rate to the point of not seeing it now for a couple of weeks.
Still have no idea what changed if anything even in anyone’s control… but, thought I would follow up!
I can’t paint my Felt anymore since the beginning of this week.
before it not changed colour when you used the slider, but when you pressed back, it still changed colour. not it just stays green.
Is that a bug, or did they really removed the option :frowning:
the spray bottle is still there…
greets
@shooj Since this update, my avatar is swerving to the right side without input of the Play steering controller. Before it was just fine. Happens everytime I turn on the play controllers
You should contact support. If calibration doesn’t help then they may be dead.
I had an issue with my controllers post 1.72 and was recommended to do a reinstall of Zwift. Ive done 1 ride since and that seemed to have fixed it so maybe give that a go
Did a workout this morning in Richmond, but the Zwift automatic activity-naming has put me on Sugar Cookie, which isn’t even in Richmond. I haven’t edited the title, but went into the edit screen to check the full title as I couldn’t see it in ZCA.
This is an old bug
Hey Zwifters!
We’ve issued a version 1.72.2 update that addresses the reported Log files issue.
Phased rollout has begun for all platforms.
@Telhma_Thorsdottir If you have a moment, it would be helpful to get a little more information about what you’re observing.
Could you please share a screenshot or photo of what the Garage looks like when you’re unable to adjust the color? That will help us confirm the specific frame model and if there are any other paint jobs that might be in effect. Thanks!
