Game Update 1.46 [August 2023]
Hi Zwifters!
Phased rollout of Zwift game version 1.46 begins today on PC, macOS, and Android platforms. iOS and tvOS is planned to begin tomorrow.
  • Introduced a new race results screen that will now appear for any race or event that has race results enabled. The screen is designed to be more useful to Zwifters immediately after a race by showing more relevant information in a cleaner format.
  • Made adjustments to Pack Dynamics in Makuri Islands in order to make groups feel even smoother. See this thread for details on PD 4.1
  • Zwift Play: In Events, fixed an issue where the Action Bar could incorrectly appear when using the in-game chat feature.
  • Fixed a potential crash that could occur when group ride leaders sent chat messages to the group.
  • Fixed an issue where the Scotland Loch Loop route progress bar would disappear after the second lap.
  • Fixed an issue where the running pairing screen could be shown after selecting a cycling Training Plan.
  • Fixed an issue where you could be pushed to the sides of the group if activating a Draft Boost power-up in a cycling group while a steering device is used.
  • Fixed an issue where the “Searching for Devices” window could get stuck open in the Pairing screen.
  • Fixed an issue on the Save Activity screen where “No Club” sharing preference would not be remembered between sessions.
  • Fixed an issue where sound effects were not playing in the Garage and Drop Shop menus.
  • Fixed an issue where runners may appear to clip through the roadway on the France Champs-ÉlysĂ©es route.
  • Fixed an issue where grass and concrete terrain could appear black after doing an activity in Scotland and then immediately starting another activity in a different world.
  • Fixed an issue which caused avatars to appear dimly-lit in the Garage.
Apple TV, iOS, Android:
  • Fixed an issue where custom workouts would not sync properly to mobile platforms and Apple TV.
  • Fixed an issue where custom workouts would appear on mobile platforms and Apple TV after being deleted on Windows or macOS.
  • Fixed an issue where devices would not auto-connect after ending an activity and immediately starting a new activity.
Android:
  • We’re beginning to roll out haptic feedback for Zwift Play controllers on Android. You’ll now feel your controllers vibrate when you return a Ride On, ride over boost strips and hazards in Repack Rush, use power-ups, brake, and more.
  • Fixed an issue where one Zwift Play controller may not automatically reconnect when starting a new session.
  • Fixed an issue where Climb Portal roads were invisible on some specific Android devices.
iOS:
  • When sending log files to Zwift from the Login Screen, instructions are now provided if an email client isn’t configured on the device.
macOS, iOS:
  • Fixed a potential crash that could occur in Climb Portal.
UPDATE August 17
  • Phased rollout to macOS and tvOS has begun.
  • Rollout to more Windows / macOS / Android devices continues.
UPDATE August 18
  • Rollout to all OS platforms is complete. Please update at your earliest convenience.
Any questions about this release? Ask here!
Thanks @shooj
As Pack Dynamics 4.1 is currently already live in Makuri Islands, does this suggest that we are ‘very close’ to having PD 4.1 switched on (as default) across the whole platform?
Cheers :+1:
Adjusted to note this is Makuri Islands.
With no sizable events or even pace partners and not being on the guest world rotation it’s hard to actually see how this functions. @shooj are there going to be opportunities to get sizeable groups on Makuri?
When will there be a fix for the broken powerup selection when turning into climb portal from a freeride?
A fix for the camera 0 controls would be great as well. really furstrating that it’s be broken for a month or two and not a priority to resolve in the next update.
Hey everyone, quick FYI:
Pack Dynamics 4.1 will be turned on for the remaining worlds Sunday night pacific/early morning Monday UTC and EU.
This means that everywhere else will have it from that point forward.
Thanks for the update @xflintx
 appreciate it.
For now, there are plenty of events scheduled in Makuri Islands (ZP is currently showing 114 events over the next 3 days), so I’m sure some of them will fill up nicely to be able to give PD 4.1 a good test before the wider roll out. :+1:
There are already a significant number of events using PD4.1: The at Home Cycling & Running Virtual Training App
Did this issue make the cut/fix list?
Can @DavidP give us a summary of the changes in PD4.1 so we don’t have to read over 500 messages to try and figure out what is going on?
At a high level, the changes are:
  1. Preventing easy overtake of someone not drafting to reduce the effectiveness of “slingshotting” someone and lower the acceleration.
  2. Dynamic draft coefficient (CdA) changes - Zwifter’s frontal area relative to draft is adjusted depending on the situation, accounting for a) attacking and b) high draft situations
  3. Changes to maximum draft possible and the draft cone - by changing the way the draft cone is calculated in specific situations, we can help the pack feel smoother and more realistic to attain the original goals of PD4.
If you’re looking for specific numerical changes, we aren’t disclosing those. Our changes from PD4 to PD4.1 are actually super small numbers tweaks guided by the main goals David set out in the original post, all coming together to produce the overall feeling we’re looking to achieve when riding in the packs on Zwift. “Small tweaks” are generally something like (and I’m making this up just for an example) changing the effect of headwind on the rider when surrounded by a number of riders by .01 or .1, reducing draft cone size by .025m, etc.
Thank you! I know @DavidP has made some additional changes from when those test events first started 3 months ago.
Those three main points are directly from the most recent document David sent around internally, so they’re the most up to date. A lot of the changes are numerical, as mentioned, but the overall goals and larger changes to achieve those goals haven’t changed.
How many of those are races with meaningful participation numbers? Last I looked there was nothing useful. Not too relevant anymore though since 4.1 is turning on everywhere at the end of the weekend.
Just need the auto brake removed from 4.1 now.
@Rhino-Racing Sorry if I’ve missed the thread on this elsewhere, but could you please explain this one a bit more or point me to another thread where it’s described? Just wanted to make sure I correctly understood the issue.
When using camera view 0, if you press the up or down arrow keys to pan around, the action bar will pop up and then subsequent left/right arrows can move along items in the action bar. The panning still works but it’s very annoying.
When in camera view 0, the action bar shouldn’t popup at all.
Thanks! We’ll follow up on this.
Where is Zwift Play for those of us not in the US ,UK or EU? We’ve all paid for its development and upgrading but are denied the in-game advantages it affords, particularly for racing.
