To fix this, several people on this thread have uninstalled and reinstalled Zwift (sometimes more than one time) to get the Mac to ask for the Local Access network permission. Once the Mac has done that the Companion app should connect.
You can also go (on your Mac) to Settings->Privacy&Security->Local Network and see if Zwift is listed. If not, you’ll need to do the uninstall/reinstall of Zwift as said above. If you >do< see Zwift in the list, try toggling the switch beside Zwift OFF, then ON.
Hopefully this will get your Companion app to connect.
After updating my iPhone 13 to iOS 18 and my MacBook pro to MacOS Sequoia 15.0 i can not connect with the companion app. I am on the same network and installed te latest update for de companion app. The app does not find my zwift ride anymore. Before all updates, there were no problems. How can I fix this?
Thank you and sorry for my late response
No. The problem from what I understand is more sophisticated more than expected
To solve it i (due to and thanks to Zwift support) took time.
But yes it was resolved.
Yet, I think that Zwift more easy to solve it to the IOS users.
Thank you
And thank Zwift fast response
My best guess is it’s either:
- A Sequoia issue (which would mean Zwift needs an update); and/or
- You need to update to the latest Zwift Ride controllers firmware via the Companion App.
I don’t have this problem, but I’m running Zwift on AppleTV 4K 3rd Gen (tvOS 18), and I updated my controller firmware two days ago.
But I just updated my MacBook Air to Sequoia, so maybe I’ll run a test tomorrow.
This solution does not work for me. I have uninstalled and reinstalled the Zwift software several times. And yes, each time I was asked for access to the network. Even deactivating and activating Privacy&Security/Network Access didn’t help.
Companion App (iPhone iOS 18) and iPad Zwift App (iOS 18) work together perfectly. Only the new Mac OS 15 causes problems.
I hope for a fix from Zwift soon.
I tried the solution that is mentioned in the same treat that was made some days ago and that solution worked for me
Same issues for me tried everything no change. So ran Zwift on one iphone and CA on another iphone no dropouts so far . So looks like a Macos V15 issue.
With the new update to macOS 15.0.1 the connection problems have disappeared! At least for me.
Thanks for all the reports, everyone. I have been keeping an eye on this, and so far from my findings online this seems to be an issue on Apple’s side. There hasn’t been anything official from them recognizing this as far as I can tell.
I was holding off uninstalling to troubleshoot internally, and I can confirm that macOS 15.0.1 did solve this. Upon updating my macbook, the same Zwift instalation that was not connecting to ZC now prompts for local connections again and ZC connects as expected.
My problem may be slightly different. The companion app on my iPhone has only ever paired to my iPad like two out of 15 times since I started using zwift. Have reinstalled apps and reset hardware but so inconsistent.
Is there some button or specific trigger that the companion app needs to connect that I’m missing?
No it’s probably something related to your home network. If it ever worked then the devices themselves are capable of finding each other and it is unlikely to be a permission problem on the device unless something changed since the last time it worked. Not all of the advice below is strictly required but generally a good idea when troubleshooting…
- Power cycle the network equipment and both devices
- Put the devices in airplane mode and then enable WiFi manually so there’s no chance of switching to cellular data
- Make sure both devices are on the same WiFi network
- If the router has both 2.4GHz and 5GHz transmitters using the same network name, rename the 2.4GHz network to something else to force both devices onto the 5GHz band.
- Don’t use VPNs
ChatGPT app answers everything
Have you rebooted your computer and then tried to connect ZC again?
Mine fails after every reboot, even after installing 15.0.1.
I just tried a reboot and it is still working as expected. If you continue to have issues, please reach out to our support team. I can take a look at your logs on our side and see if there’s anything weird happening.
@John_Zwift Here’s something interesting: Instead of starting Zwift through the Zwift Launcher (which later starts ZwiftAppSilicon), I manually started ZwiftAppSilicon.
When I launch it manually, it asks for my password, and after successful login it connects to the Companion app every single time. Reboot/shutdown/sleep doesn’t matter. It always works when i launch it manually.
Trying to use the Zwift launcher on the other hand has the connection issue.
Interesting. I’ll reach out through DM with some questions and try to get your logs so we can dig in.
Hi John:
When I went to join the Tour today with 1 min left, the companion app would not let me join the pen and crashed my Zwift session. This has never happened to me before and I am using Zwift for 5 years now. I usually join an event by hitting my iPad and not the comp app while both are running. Also the turn around button on the comp app never works for me so I use the iPad as well. Normal running on iPad and comp app on iPhone. Had to unplug the trainer and open a new Zwift session 3 times to restore connection. IOS 18.0.1.
Hey James - it sounds like the companion app connects and shows you the world but:
- You had a crash today, when attempting to join an event from the companion app.
- You cann U turn from the companion app, but from the iPad it works as expected.
For the crash, what was the game doing at the time, what screen was it on?
