ANT+ dongle issues windows 10 and Zwift
Hello all,
Last night my issues started with ANT+ connectivity. My HR dropped mid ride and I have since tried everything to fix it. Windows 10 is up to date, removed and re-installed zwift twice as well as removed and re-installed ant+ device and drivers probably 10 times now, tried a few different port as well. I tried on another win10 computer and it works fine with the same dongle.
When I install it, everything shows as normal, drivers install fine and no yellow flag in device manager. I launch zwift and both ANT and bluetooth show active, the trainer quickly connect through bluetooth but despite ANT+ showing active, no HR monitor is found as well as no ant in the trainer list. It briefly reappeared for a few seconds on one instance then disappeared again.
Any recommendations on what I could do? I also de-installed and re-installed ANT driver manually but no luck.
Thanks in advance
Regards
Jean S
Hi @Jean_Sebille_COALITI
Since you already tested the same dongle on a different PC, then my guess is that it could be a bad USB port on your computer. Have you tried swapping the dongle to a different USB port?
We also have this article, which has some other ideas that you might find helpful, though it sounds like you might have tried most of that already.
I tried 4 different USB ports yes. I also removed my USB extension cord and plugged directly into the USB.
@Jean_Sebille_COALITI — Then I have no other ideas. It seems to me that you’ve tried everything within reason.
Reinstalling the drivers should have fixed the issue. It could be a more complex issue with the operating system and perhaps something amiss in the registry.
Do you have a different ANT+ dongle you can try to see if that makes any difference?
change the battery?
Have you moved anything around in the environment that might be causing interference? Fans, lights, other devices, etc… When someone uses the microwave at my house (I Zwift in the basement right under the kitchen) I lose all signals for a few seconds including wifi and ant+.
Battery brand new in HR monitor, connects all good with my garmin devices and my windows laptop + zwift with same USB ant dongle. Issue seems to solely be with the fixed computer I use to zwift, I also tried rouvy and it doesn’t see ANT devices either which tells me that this is a software issue.
  1. dongle works, tried on another computer
  2. HR straps works no problem
  3. Computer installs dongle without any visual issue and even Zwift shows ANT+ active but doesn’t find devices :frowning:
That’s very puzzling and I’m sorry, but I don’t have any other suggestions at this time other than to perhaps try using a different USB ANT+ dongle, if possible, or consider Bluetooth pairing.
Unless you want to try completely re-installing Windows, but that’s like using a hammer to solve an issue where a more surgical tool might be required.
Just to check, you’re seeing the pulsing rings yeah?
yes the pulsing ring are here both around ANT and bluetooth on pairing screen
Hi Jean, what about delete the knowndevices.xml file in your Documents\Zwift folder. Like this Zwift is unaware of any device and you need to connect all again.
Let me try this
no go
Hi Jean,
looks like a Dynastream Innovations, Inc. device.
Have you forced uninstallation of device including deletion of drivers? If not try this.
If it still fails maybe try manual driver installation as described by @Dave_ZPCMR in his post.
BTW, have you checked if your USB device in Device Manager has the checkbox off relating to Power Saving Mode? Sometimes it goes off because of that especially after Win10 updates which may auto-check the box as on.
Yes I did remove device a few time as well as all drivers. I tried both ways of manual install of the ones found in Dave’s post as well as the one on wahoo website per example, no luck unfortunately. It did re-appear once upon zwift startup for about 5 seconds after doing one of those operation then all ANT signal were still in the list with a big “no signal” watermark over it :frowning:
Could you attach Log.txt and ComputerSpecs.txt from Zwift’s log folder in your Documents folder?
Tried that, it was selected, I unselected it but no help in Zwift
How would I attach a file Oliver? I also put them in a google drive but it does not let me add the link here :frowning:
Copy and paste the text contents into your post.
here is log.txt part 1:
[7:58:26] Log Time: 7:58:26 2022-03-04
[7:58:26] Game Version: 1.22.4(100456) e69aa1e00e3650b9e26593fd3102b4957de7075d
[7:58:26] Config: Shipping
[7:58:26] Device: PC
[7:58:26] Launcher Version : 1.1.1
[7:58:26] Loading WAD file ‘assets/global.wad’ with file.
[7:58:26] Loading WAD file ‘assets/Environment/Ground/textures.wad’ with file.
[7:58:26] Loading WAD file ‘assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad’ with file.
[7:58:26] Loading WAD file ‘assets/UI/minimap/minimap.wad’ with file.
[7:58:26] Loading WAD file ‘assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad’ with file.
[7:58:26] Loading WAD file ‘assets/UI/layouts/layouts.wad’ with file.
[7:58:26] Loading WAD file ‘assets/Environment/GrassTextures/GrassTextures.wad’ with file.
[7:58:26] ERROR: Sky::Load(): Default not found
[7:58:26] ERROR: Sky::Load(): Japan not found
[7:58:26] ERROR: Sky::Load(): France not found
[7:58:27] Successful audio init!
[7:58:27] Loaded audio banks
[7:58:27] Initializing graphics window of size 0 x 0
[7:58:27] Attached Monitors:
[7:58:27] preferred monitor found at: 0,0
[7:58:27] GFX_Initialize: GL_version = 4.3.0 - Build 30.0.100.9955
[7:58:27] GL_vendor = Intel
[7:58:27] GL_render = Intel(R) UHD Graphics 630
[7:58:27] Checking Extensions
[7:58:27] [GFX]: Compatability profile
[7:58:27] [GFX]: GFX_Tier 0
[7:58:27] Screen reported DPI: 96 physical DPI: 54 Scale: 1.00
[7:58:27] Calculating Graphics Score
[7:58:27] GFX: Found a vendor/model match for HD GRAPHICS 6
[7:58:27] Initializing Render Targets
[7:58:27] Initializing Texture Systems
[7:58:27] Shader Loaded successfully. data/shaders/Final/Blur.psh
[7:58:27] Calling initialize_zwift_network()
[7:58:27] NETCLIENT:[INFO] CNL 3.17.2
[7:58:27] NETCLIENT:[INFO] Machine Id: 1-f4cf224f-4685-4b46-8b84-1674aa77f975
[7:58:27] Suceeded initializing graphics
[7:58:27] Shader Loaded successfully. data/shaders/Final/GFXDRAW_NoTexture.psh
[7:58:27] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured.psh
[7:58:27] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_Simple.psh
[7:58:27] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_GammaCorrect.psh
[7:58:27] Loading WAD file ‘assets/fonts/font.wad’ with file.
[7:58:27] Shader Loaded successfully. data/shaders/Final/GFXDRAW_FontW.psh
[7:58:27] Using basic graphics profile
[7:58:27] > res 1024x576(0x)
[7:58:28] Changed resolution to 1024 x 576 ( NO MSAA )
[7:58:28] > sres 512x512
[7:58:28] Changed shadow resolution to 512 x 512
[7:58:28] Syntax Error. USAGE: set VARNAME=VALUE
[7:58:28] Type ‘listvars’ for list of tweakable variables
[7:58:28] Unknown command “aniso 4”
[7:58:28] > set gSSAO=0
[7:58:28] > set gFXAA=1
[7:58:28] > set gSunRays=0
[7:58:28] > set gHeadlight=0
[7:58:28] > set gFoliagePercent=0.5
[7:58:28] > set gSimpleReflections=1
[7:58:28] > set gLODBias=1
[7:58:28] > res 1920x1080
[7:58:28] Changed resolution to 1920 x 1080
[7:58:28] > sres 1024x1024
[7:58:28] Changed shadow resolution to 1024 x 1024
[7:58:28] OpenGL 4.3.0 - Build 30.0.100.9955 initialized
[7:58:28] Graphics Vendor: Intel
[7:58:28] Graphics Renderer: Intel(R) UHD Graphics 630
[7:58:28] RAM: 4GB
[7:58:28] CPU: Intel(R) Core™ i3-8100 CPU @ 3.60GHz
[7:58:28] ANT : TX POWER ID
[7:58:28] ANT : RESET Complete, reason:
[7:58:28] ANT : RESET_CMD
[7:58:28] ANT : Clearing network key on network 0.
[7:58:28] ANT : Clearing network key on network 1.
[7:58:28] ANT : Clearing network key on network 2.
[7:58:28] ANT : ANT USB receiver found
[7:58:28] Downloader: “MapSchedule_v2.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[7:58:28] Downloader::Update m_filesCompleted.push_back name=MapSchedule_v2.xml success=1
[7:58:28] Game::GAME_onFinishedDownloadingMapSchedule filename=MapSchedule_v2.xml err=0 state: m_filesPending: <> m_filesCurrent: <> m_filesCompleted: <MapSchedule_v2.xml> m_filesFailed: <>
[7:58:28] Downloader::ForgetCompleted path=MapSchedule_v2.xml
[7:58:28] Loading WAD file ‘assets/UI/Achievements/goals.wad’ with file.
[7:58:28] Loading WAD file ‘assets/UI/Achievements/achievements.wad’ with file.
[7:58:28] Registered segment 1 with hash id 888000
[7:58:28] Registered segment 2 with hash id 888001
[7:58:28] Registered segment 3 with hash id 888002
[7:58:28] Registered segment 4 with hash id 888003
[7:58:28] Registered segment 5 with hash id 888004
[7:58:28] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_ExtAlpha.psh
[7:58:28] Loading Shader GaussianBlur
[7:58:28] ERROR: Missing Vertex Shader asset data/shaders/Final/GaussianBlur.vsh
[7:58:28] [GFX]: ERROR: GFX_CreateShaderFromFile(GaussianBlur[0][0]) failed!
[7:58:28] Shader Loaded successfully. data/shaders/Final/Simpleshader.psh
[7:58:28] Shader Loaded successfully. data/shaders/Final/gde_nolighting.psh
[7:58:28] Shader Loaded successfully. data/shaders/Final/shadowmap.psh
[7:58:28] Shader Loaded successfully. data/shaders/Final/shadowmap_instanced.psh
[7:58:28] Shader Loaded successfully. data/shaders/Final/shadowmapHair.psh
[7:58:28] Shader Loaded successfully. data/shaders/Final/Glossy_shadowmapped.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/Road.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/RoadAccessory.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/RoadWet.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/HeatHaze.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/CausticPass.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/crepuscular.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/beam.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/beam_inside.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/defaultWorld.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/defaultWorldAO.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/defaultWorldBillboard.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/defaultworldphong.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/defaultWorldSimple.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/Hologram.psh
[7:58:29] Shader Loaded successfully. data/shaders/Final/RainbowHologram.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/Glossy_locked.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/londonTerrainShader.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/londonTerrainShader_HeightMap.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/franceTerrainShader.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/franceTerrainShader_HeightMap.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/japanTerrainShader.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/japanTerrainShader_HeightMap.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/innsbruckTerrainShader_HeightMap.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/innsbruckTerrainShader.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/bolognaTerrainShader_HeightMap.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/bolognaTerrainShader.psh
[7:58:30] Shader Loaded successfully. data/shaders/Final/yorkshireTerrainShader.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/yorkshireTerrainShader_HeightMap.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/richmondTerrainShader.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/richmondTerrainShader_HeightMap.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/WorkoutHologramPortal.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/WorkoutHologramPortalRing.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/FinalCopy.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld_Terrain.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld_TerrainHeightMap.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/shadowmap_TerrainHeightMap.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/WatopiaDesert_TerrainHeightMap.psh
[7:58:31] Loading Shader WatopiaDesert
[7:58:31] ERROR: Missing Vertex Shader asset data/shaders/Final/WatopiaDesert.vsh
[7:58:31] [GFX]: ERROR: GFX_CreateShaderFromFile(WatopiaDesert[0][0]) failed!
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld_instanced.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld_notShadowed_instanced.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld_instanced_TerrainHeightMap.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld2Layer.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/defaultWorld2Layer_instanced.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/vegetation.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/vegetationTerrainHeightmapInstance.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/vegetationInstance.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/vegetationShadowmap.psh
[7:58:31] Shader Loaded successfully. data/shaders/Final/vegetationShadowmapInstance.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/wire.psh
[7:58:32] Loading Shader wireShadow
[7:58:32] ERROR: Missing Vertex Shader asset data/shaders/Final/wireShadow.vsh
[7:58:32] [GFX]: ERROR: GFX_CreateShaderFromFile(wireShadow[0][0]) failed!
[7:58:32] Shader Loaded successfully. data/shaders/Final/accessory_instanced.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/Hair.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/defaultWorld_notShadowed.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/skinShader.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/shadowmapSkin.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/skinShaderHologram.psh
[7:58:32] [ZWIFT]: GFX_Tier 0
[7:58:32] Shader Loaded successfully. data/shaders/Final/fxaa.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/UberPostprocess.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/Downsample4x4Luminance.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/Downsample4x4MeanMax.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/Brightpass.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/bloomFinalPass.psh
[7:58:32] Loading Shader RadialBlur
[7:58:32] ERROR: Missing Vertex Shader asset data/shaders/Final/RadialBlur.vsh
[7:58:32] [GFX]: ERROR: GFX_CreateShaderFromFile(RadialBlur[0][0]) failed!
[7:58:32] Shader Loaded successfully. data/shaders/Final/Invisibility.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/Invisibility_locked.psh
[7:58:32] Loading WAD file ‘assets/Environment/SkyDome/sky.wad’ with file.
[7:58:32] Shader Loaded successfully. data/shaders/Final/sky.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/stars.psh
[7:58:32] Shader Loaded successfully. data/shaders/Final/moon.psh
[7:58:33] Shader Loaded successfully. data/shaders/Final/defaultParticles.psh
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Accessories.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Bikes/bikes_config.wad’ with file.
[7:58:33] Loading WAD file ‘assets/UI/WhiteOrangeTheme/Customization/Customization.wad’ with file.
[7:58:33] Loading WAD file ‘assets/UI/WhiteOrangeTheme/JerseyIcons/JerseyIcons.wad’ with file.
[7:58:33] Wad assets/Humans/Accessories/Accessories.wad at 0x367574ed already loaded
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Glasses/ZwiftGlasses.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Hair/Hair.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Hats/Hats.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Headband/Headband.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Helmets/ZwiftHelmet.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Shoes/Shoes.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Accessories/Socks/Socks.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Originals/originals_01.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Originals/originals_02.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Pro_Teams/pro_teams_01.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Pro_Teams/pro_teams_02.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Companies/Companies.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Companies/Companies2.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Companies/Companies3.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Companies/Companies4.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Companies/Companies5.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Originals/camo_01.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Specials/specials_01.wad’ with file.
[7:58:33] Loading WAD file ‘assets/Humans/Jerseys/Events/Events.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Events/Events2.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Clubs/Clubs.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Clubs/Clubs2.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Clubs/Clubs3.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Pack01/Pack01.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Pack02/Pack02.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Jerseys/Charities/Charities.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Humans/Clothes/Clothes.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Zwift/Steel/ZwiftSteel.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Campagnolo/SuperRecord/SuperRecord.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Cassette/Cassette.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Shimano/DuraAce/DuraAce.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Shimano/DuraAce9200/DuraAce9200.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Specialized/Sworks/Sworks.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Sram/SramRed/SramRed.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Sram/SramRed2021/SramRed2021.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/Sram/SramXX1/SramXX1.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Components/CeramicSpeed/CeramicSpeed.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/data.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/BmcSLR01/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/BmcTimemachine01/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/Buffalo/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/BuffaloQhubeka/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/CannondaleCaad12/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/CannondaleEvo/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/CannondaleSynapseDisk2018/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/CannondaleSystemSix2019/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/Canyon_Aeroad/frame.wad’ with file.
[7:58:34] Loading WAD file ‘assets/Bikes/Frames/Canyon_Speedmax/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Canyon_Ultimate/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Cello/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/CerveloP5/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/CerveloP5x/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/CerveloR5/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/CerveloS3D/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/CerveloS5/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/DefaultOrange/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/DiamondBack_Andean/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/GiantDefyASL/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/GiantPropelAdvanced/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/LivLangma/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Parlee_ESX/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Pinarello_Dogma/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Pinarello_F8/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Pinarello_TT/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/PinarelloBolideTT2018/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/PinarelloDogmaF102019/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/RidleyHelium/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Scott_Foil/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Specialized_Allez/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Specialized_Amira/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Specialized_Roubaix/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Specialized_Tarmac/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Specialized_Venge/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/SpecializedAllezSprint2019/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/SpecializedShiv/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/SpecializedShiv2019/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/Trek/frame.wad’ with file.
[7:58:35] Loading WAD file ‘assets/Bikes/Frames/TrekEmonda/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/TrekMadone/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/VentumOne/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_Aero/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_Bat/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_BW/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_BWConcept/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_Carbon/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_Concept/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_Safety/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_Steel/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/Zwift_TT/frame.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Frames/ZwiftSkeletal/frame.wad’ with file.
[7:58:36] Unable to open WAD file “assets/Bikes/Frames/ScottSparkMountainBike2019/frame.wad”.
[7:58:36] ERROR: Could not load wad file: assets/Bikes/Frames/ScottSparkMountainBike2019/frame.wad
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/data.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zipp/Zipp_808_Firecrest/Firecrest808.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zipp/Zipp_404_Firecrest/Firecrest404.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zipp/Zipp_202_Firecrest/Firecrest202.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Lightweight/Meilenstein_Lightweight/Meilenstein_Lightweight.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Enve/EnveSES_2.2/Enve22.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Enve/EnveSES_3.5/EnveSES_3.5.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Enve/EnveSES_6.7/Enve67.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Enve/EnveSES7.8/EnveSES7.8.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Enve/EnveSES_8.9/Enve89.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zipp/Zipp_Disc/Disc.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Mavic/CosmicCXR60c/CosmicCXR60c.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zwift/Zwift_Concept/Concept.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zwift/Zwift_Classic/Classic.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zwift/Zwift_BW/BW.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zwift/ZwiftSkeletal/wheels.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zwift/Zwift_Bat/wheels.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Campagnolo/Campagnolo_Bora_Ultra/BoraUltra.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Bontrager/Aeolus5/Aeolus5.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Specialized/Roval/Roval.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Zwift/Zwift_Safety/Zwift_Safety.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/DefaultOrange/DefaultOrange.wad’ with file.
[7:58:36] Loading WAD file ‘assets/Bikes/Wheels/Giant/SLR/PropelAdvanced.wad’ with file.
[7:58:37] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/JerseyIcons/Zwift_RaceLeader_thumb.tga
[7:58:40] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/JerseyIcons/TealPink2020_thumb.tga
[7:58:42] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/JerseyIcons/Twenty242021_thumb.tga
[7:58:45] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/RunningShirts/TealPink2020_thumb.tga
[7:58:47] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/RunningShorts/TealPink2020_thumb.tga
[7:58:51] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/Glasses/Glasses_TealPink2020Glasses01_thumb.tga
[7:58:51] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/Glasses/Glasses_TealPink2020Glasses02_thumb.tga
[7:59:00] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/Zwift_RaceLeader_thumb.tga
[7:59:00] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/TealPink2020_thumb.tga
[7:59:00] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/Twenty242021_thumb.tga
[7:59:00] FILE : Unable to load UI/WhiteOrangeTheme/Customization/RunningShirts/TealPink2020_thumb.tga
[7:59:00] Shader Loaded successfully. data/shaders/Final/DropShadow.psh
[7:59:00] Loading WAD file ‘assets/Humans/Male/male.wad’ with file.
[7:59:00] Loading WAD file ‘assets/Humans/Male/male_textures.wad’ with file.
[7:59:00] Loading WAD file ‘assets/Humans/Female/female.wad’ with file.
[7:59:00] Loading WAD file ‘assets/Humans/Female/female_textures.wad’ with file.
[7:59:02] Shader Loaded successfully. data/shaders/Final/bib.psh
[7:59:02] Loading WAD file ‘assets/UI/Challenges/challenges.wad’ with file.
[7:59:02] ERROR: CriticalPowerCurve::Save Query; pOutDataPoints is NULL
[7:59:02] Loading WAD file ‘assets/UI/flags/flags.wad’ with file.
[7:59:03] Loading WAD file ‘assets/UI/Challenges/challenges.wad’ with file.
[7:59:03] Loading WAD file ‘assets/UI/Challenges/challenge_italy.wad’ with file.
[7:59:03] Shader Loaded successfully. data/shaders/Final/defaultWorldBillboardGrass.psh
[7:59:03] SaveActivityService::GameLoadLevel – Skipped Invalid World: 0
[7:59:03] GAME_LoadLevel() worldID = 0
[7:59:03] Loading WAD file ‘assets/Worlds/world0/data.wad’ with file.
[7:59:03] Loading WAD file ‘assets/Worlds/world0/data_1.wad’ with file.
[7:59:03] Loading WAD file ‘assets/Environment/Road/FreshRoad/FreshRoad.wad’ with file.
[7:59:03] Loading WAD file ‘assets/Environment/Road/Cobblestone/Cobblestone.wad’ with file.
[7:59:03] Loading WAD file ‘assets/Environment/Road/DirtRoad/DirtRoad.wad’ with file.
[7:59:04] Loading WAD file ‘assets/Environment/Road/snowy/SnowRoad.wad’ with file.
[7:59:04] Couldnt load road tex Environment\Road\FreshRoad\FreshRoadOneLine.tga
[7:59:04] Couldnt load road tex Environment\Road\FreshRoad\FreshRoadOneLineNml.tga
[7:59:04] Shader Loaded successfully. data/shaders/Final/colorRoadShader.psh
[7:59:04] AK::LoadBank(World0.bnk) failed: 2
[7:59:04] STEERING : Steering Mode Set to: None
[7:59:04] Save Profile Request: Repack Ridge Reset
[7:59:04] Shader Loaded successfully. data/shaders/Final/water.psh
[7:59:04] Shader Loaded successfully. data/shaders/Final/water_noholes.psh
[7:59:04] Loading WAD file ‘assets/Humans/Jerseys/Originals/originals_01.wad’ with file.
[7:59:05] Loading WAD file ‘assets/Humans/Jerseys/Originals/originals_02.wad’ with file.
[7:59:05] Loading WAD file ‘assets/Humans/Jerseys/Originals/originals_01.wad’ with file.
[7:59:05] Got an access token
[7:59:05] Attempting Token Login…
[7:59:05] ANT : Setting network key on network 0…
[7:59:05] ANT : Network Key Set
[7:59:05] ANT : Setting network key on network 1…
[7:59:05] ANT : AUC message id=64
[7:59:06] ANT : Setting network key on network 2…
[7:59:06] ANT : Network Key Set
[7:59:06] m_bDraftLockFixEnabled: ON (by default, feature-flag unavailable)
[7:59:06] m_bPackDynamics25CollisionPushBackRemoval: ON (by default, feature-flag unavailable)
[7:59:06] m_bDefaultRubberbanding: ON (by default, feature-flag unavailable)
[7:59:06] resize: 1904 x 1041
[7:59:06] Loading WAD file ‘assets/Worlds/world1/data_1.wad’ with file.
[7:59:07] Loading routes…
[7:59:07] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world1/routes/routes11.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world1/routes/routes11.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world1/routes/routes12.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world1/routes/routes12.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world1/routes/routes16.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world1/routes/routes16.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world1/routes/routes24.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world1/routes/routes24.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world1/routes/routes33.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world1/routes/routes33.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world1/routes/routes36.xml
[7:59:07] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world1/routes/routes36.xml
[7:59:07] WARN : Load Route Warning - failed to open “data/Worlds/world1/routes/routes71.xml”
[7:59:07] Route manager info: 71 routes
[7:59:08] NETCLIENT:[INFO] Requesting seeds…
[7:59:08] NETCLIENT:[INFO] Session ID: 7ba04c41-790f-4c8c-bce2-47a4bd34133f
[7:59:08] NETCLIENT:[INFO] Logged in
[7:59:08] NETCLIENT:[INFO] Next seeds fetch will happen in 50 minutes
[7:59:08] NETCLIENT:[INFO] Player ID: 4517791
[7:59:08] NETCLIENT:[INFO] Analytics ID: c766f75a-2d3a-41c9-9b81-9f2c2e97bb37
[7:59:08] NETCLIENT:[INFO] TCP disconnected
[7:59:08] NETCLIENT:[INFO] TCP host 54.189.56.123:3023
[7:59:08] NETCLIENT:[INFO] Connecting to TCP server…
[7:59:08] NETCLIENT:[INFO] Saying hello to TCP server (largest wa is 0)
[7:59:08] Loading WAD file ‘assets/Workouts/workouts.wad’ with file.
[7:59:08] Tried to load a valid xml file, but it seems to not really be a ZWO file?
[7:59:08] LoadWorkout failed to load.
[7:59:08] Failed workout path: TrainingPlans/3day13one_FESTIVAL.xml
[7:59:08] Failed workout path: TrainingPlans/trainingplans.xml
[7:59:08] Failed workout path: TrainingPlans/3day13one.xml
[7:59:08] Failed workout path: TrainingPlans/5kRecordBreaker.xml
[7:59:08] Failed workout path: TrainingPlans/6wk_FTP_Builder.xml
[7:59:08] Failed workout path: TrainingPlans/8wkRacePrep.xml
[7:59:08] Failed workout path: TrainingPlans/12wk_Winter_Plan.xml
[7:59:08] Failed workout path: TrainingPlans/Cyclist_10K.xml
[7:59:08] Failed workout path: TrainingPlans/Fondo.xml
[7:59:08] Failed workout path: TrainingPlans/GC_TrainingPlan.xml
[7:59:08] Failed workout path: TrainingPlans/GranFondo.xml
[7:59:08] Failed workout path: TrainingPlans/Gravel_Grinder.xml
[7:59:08] Failed workout path: TrainingPlans/PRL100_2018.xml
[7:59:08] Failed workout path: TrainingPlans/PRL46.xml
[7:59:08] Failed workout path: TrainingPlans/TT_Build.xml
