Zwift Play too many bluetooth connections
Hi Just bought Zwift Play. Fitted OK to Stages Sb20 bike. Paired up with Apple TV and all sensors work fine including a heart rate monitor. Tried to pair Play up - “too many bluetooth connections” - Followed the advice to pair using Zwift companion and get the same issue - is there a work round - or should I just return play for a refund
Are you pairing everything through Companion? That should work with Apple TV. The Apple TV device is the limiting factor here.
Both ways it seems to be limited through Apple TV and Zwift Companion – wondering if I just go back to screen mirroring off my IPAD?
EDIT: Removed Email signature.
There are people that use the Zwift Play controller with ATV and the companion app.
@Daren isn’t this how you do it?
Yes, I’ve been using Zwift Play and Companion with my Apple TV.
@Richard_Davies4 I presume you’re going through Companion for all connections (I think that’s the only way you can use Companion as a bridge anyway).
I’ve been riding with my smart trainer, HRM and both Play controllers paired. Mine is an Apple TV 4K from this year.
I have no idea what is happening - mine is a 6 month old Apple TV cube. I noticed just now on a ride that now the bluetooth connection thing came on without the Play turned on , which has never happened before in the last 6 months. Something weird is going on. I think I will try and turn everything off , leave it for a bit and then start from scratch. I have raised a query with Zwift, so if I get any further advice I will let you know. Thanks for your help so far. You have to realise I am about as technical as a dog!
Tried bioth ways and same issue
Started using Zwift play today,all ok,but the blue lit up Z buttons on each play unit kept flashing during the ride,is this normal🤔
Were all the functions working in the ride whilst they were flashing?
Didnt even get that far Stuart as couldn’t get connected
My reply was for Peter
This sounds similar to this issue linked below. Did it persist after rebooting Apple TV and rebooting the phone?
Hi @Richard_Davies4 welcome to Zwift forums.
Shuji at Zwift HQ here - there’s a lot of very experienced fellow Zwifters sharing their knowledge, but I can see things in your server logs that they of course can’t.
  1. One thing I’m seeing is that your Apple TV is on a slightly older version of tvOS (16.1.0). Apple’s Support site says the latest version is 16.5. Can we start by manually updating ATV’s operating system? Sometimes, this makes a difference, and at minimum, we’re eliminating a variable that might not be a factor for others.
  2. It may be helpful here to reset the main Zwift app so that it “forgets” the devices it’s paired to in the past. On an AppleTV - the only way to do that is to uninstall Zwift and reinstall. Would you try that once you’ve updated tvOS? Did that clear up this issue?
  3. If no - please be sure both controllers are fully charged. Fully charging is important for the next step
  4. We’re in the middle of a phased rollout of new firmware v1.1.0 for Play. By tomorrow, it will be available to all Play owners. Here’s a link to the how-to video. 99% sure firmware v1.0.0 vs v1.1.0 is NOT a root cause for your issue, but more as an FYI to eliminate variables for further triage.
The pairing screen is quite unintiitive IMHO for pairing through Companion, so it’s very easy to not be doing it correctly.
You need to press the button called (something like) Pair Via Companion, and then it switches to a different Pairing screen that has an icon for your phone at top right. Companion needs to be running and BT on on your phone or it won’t see your phone.
Whem you’ve switched to this different Pairing screen the button changes to “Pair Via Bluetooth” which is the confusing bit for me - this button looks kind of like a title for the screen but in fact it’s a button to change to the screen of that name (to go back to pairing via your ATV).
It seems like your ATV is automatically trying to connect to those devices since it had “seen” them before. You could try to do a reset of your ATV and make sure that you don’t re-pair your devices.
Yes Stuart.Since I last posted I’m having connection problems now.works ok on my iPad,Apple tv is a nightmare,on 43.00
My Apple TV will show 4 of the play controllers but only two of them will show fully charged and WIFI which is great but I’m already using my three blue tooth connection for my trainer, power and heart monitor. Now when I go into my Companion app which I have already uninstalled and reinstalled it it will pick up my Kickr trainer and nothing else. Apple tv OS 16.5 and Companion is 3.48 if this helps.
What’s the status of fixing the blue tooth connection between the controllers and the Companion app. I tried again last night and the Companion app would not recognize the Controllers. If not fixed soon I would like to start the return process please. No use having something that won’t connect through the Companion app through my Apple TV.
It’s being looked at. There are threads about it in the Zwift Shop section.
Well can you give me the hyper link to fixes since they still will not connect to the Companion app through Apple TV or my iPhone
Not sure why I have to investigate the fixes for this issue.
