Zwift Play Firmware Release Notes
To get the most out of your Zwift Play controllers, please ensure you’re always using the latest firmware.
Check out this article for info on updating your Zwift Play firmware.
Zwift Play firmware version 2.0.1 (May 19 2026)
UPDATE October 5 2026
Play firmware update v 2.0.1 is available.
  • iOS only: Update Zwift Companion to version 3.89.2 or newer in the Apple App Store prior to updating Play firmware.
UPDATE 2.0.1 HAS BEEN PAUSED. See this thread for details.
Firmware version 2.0.1 for Zwift Play controllers introduces a significant change.
  • A linking feature combines left and right controllers to reduce the number of Bluetooth connections required. The Pairing Screen will show one combined Play icon.
  • Once paired, the battery icon shows the lower charge level of the two controllers.
  • Pair with a single Bluetooth connection.
    • Minimize the number of Bluetooth connections required for AppleTV.
    • Streamline your setup by using the Bluetooth bridge feature on the Wahoo KICKR Core v2 or JetBlack Victory. By pairing your peripherals directly to the trainer, you reduce the number of active signals. Note: You must first update your trainer’s firmware using the Wahoo or JetBlack app.
  • Bug fixes
Note: This update will require you to re-pair your Play controllers to the game. Afterward - both controllers will link automatically.
If you run into any issues, use the Zwift Companion app to confirm both controllers have updated successfully to v 2.0.1.
Zwift Play firmware version 1.3.1 (April 24 2024).
  • Updated the connection parameters to further reduce latency
Zwift Play firmware version 1.3.0 (February 14 2024)
  • Improved connection stability
Zwift Play firmware version 1.2.1 (October 6 , 2023)
  • Updated Bluetooth timeout parameters
  • Fixed a potential issue causing unexpected unit resets
Zwift Play firmware version 1.2.0 (August 27 2023)
  • Updates to Bluetooth connection stability - notification frequency, connection parameters, addition of keep-alive notification
Zwift Play firmware version 1.1.1 (July 14, 2023)
  • Minor bug fixes
Zwift Play firmware version 1.1.0 (June 23, 2023)
  • Charging LED behavior fixed during sleep mode transition.
  • Improved steering paddle sensitivity.
  • Added metrics to detect sensors drifting.
  • Manual calibration implementation.
  • Updated bootloader to allow recovery when firmware upgrade fails.
  • Bug fixes.
Zwift Play firmware version 1.0.0 (January 2023)
  • Zwift Play includes firmware v1.0.0 at its product launch.
