To get the most out of your Zwift Ride, please ensure you’re always using the latest firmware.
Check out this article for instructions on updating your Zwift Ride firmware.
Zwift Ride Firmware v1.2.0 update (24th September 2024)
- Fixed an issue where the controllers will not power off when the charging cable is connected
 - Fixed an issue where the controller does not power off in certain conditions.
Zwift Ride Firmware v1.1.0 update (26 June 2024)
- Haptic feedback enabled.
 - Updated the LED and battery behaviors
 - Updated connection parameters to improve stability
 - Various bug fixes.
Known Issue
- Compatibility issue when using a mix of firmware version 1.0.0 on the left controller and version 1.1.0 on the right controller. If this happens - power on the left controller first, then the right.
