To get the most out of your Zwift Hub, please ensure you’re always using the latest firmware.
Check out this article for info on updating your Zwift Hub firmware.
Zwift Hub Firmware v5.2.2 update: 9th October 2023
- Implemented a recovery process for a device failing to start as expected.
Zwift Hub Firmware v5.2.0: September 2023
- Supports recovery via Zwift Companion app if a firmware update fails.
- Bluetooth connection parameters updated to improve connectivity stability.
- Enabled Virtual Shifting when using a Zwift Click or Zwift Play with Zwift
- Implemented Real Gear Ratio Auto Detection - calculates the physical gear ratio on the bicycle using pedal cadence and flywheel speed
- Increased the power frequency from Zwift Hub to use 10Hz.
- Introduction of Zwift Protocol
Zwift Hub Firmware v4.0.1: 27th March 2023
- Fixed HR pairing bug.
- Calibration accuracy improvements.
Zwift Hub Firmware v4.0: February 2023
- Auto calibration.
- Bug fixes.
Zwift Hub Firmware v3.9: October 2022
- Fixed bug with ANT+ Speed, Cadence, and Power.
- Fix for HRM bridge reconnecting when out of range.
- Spin down adjustments.
Zwift Hub Firmware v3.8: 1st September 2022
Zwift Hub Firmware v3.4: 1st August 2022
Zwift Hub Firmware v3.1: 1st July 2022
Ride On.
Still having issues? Contact us for one-on-one help.
