Thank you, Mike.
A radical solution, but it worked!
I renamed the old Zwift directories including within Documents (so I have a backup of data if needed) and then installed a fresh version of Zwift.
Regards, David H.
Thank you, Mike.
Regards, David H.
Im a Windows user and I cant launch Zwift since the 1.1.8 update. Ive rebooted, uninstalled and reinstalled Zwift but the issue remains. Is there a fix planned or some type of work around? Any suggestions?
Hi @james_greer welcome to Zwift forums.
Another PC user upstream had success by deleting all files related to Zwift, manually downloading Zwift and re-installing. Step by step instructions here. Please pay attention to the part about backing up your custom workout files.
FYI - if you open the \Documents folder in Windows Explorer and see multiple folders called Zwift / Zwift1 / Zwift2 - that’s a symptom of files corrupted during the auto-update process. Deleting everything before a manual re-installation will solve that.
Thanks Shuji for the rapid response! Ill try the steps you supplied.
Not yet updated to 1.41, M1, no issues ![]()
I have the same problem on Windows since updating this morning. Tried the uninstall then reinstall, deleting zwift files, clearing browser cookies and cache and updating drivers. None of that has solved the issue. I emailed support and will post the outcome here as it may help someone else
Following the guidance in Shuji’s response worked for me. My previous uninstalls only uninstalled the app and I had not manually deleted the Program Files (x86)\Zwift folder. I also cleared out all previous downloads of the .exe.
I was having the same crashing issue on version 1.1.8 and did the uninstall and delete program files (while keeping a backup of the user files), then fresh reinstall, and this worked for me.
Q4: Update to 1.41 this morning. Persistent Accept Network Message popup despite several restarts of MacOS and Zwift.
Not tried on the M1 yet.
Off Zwift for a few days. Now it crashes each time I start it. What is the fix.
Unable to launch Zwift after update 1.1.8 (nothing happens when launching).
Tried uninstall/reinstall.
Windows 10 Home 64 bit (22H2)
Edit: Deleting the Zwift folder and reinstalling worked.
@Geoff_Desmond5296 @A_Carder @Mark_Barley @Sebron_Snyder @Jani
Are you using the N edition of Windows? Win N strips out multimedia files that are necessary to use the Video Screenshot features and that code is built in to 1.41 (but not enabled yet).
If you are using Windows N - this issue can be solved by finding out which Windows update version is installed and then downloading the correct Windows Media Pack. That will install the multimedia components missing from your Win N machine. Instructions are covered in this previous post.
Would you try that and report back if that solves your issue?
M2, just updated. No network message, and no crash. Yippee!
Exited, restarted, still no crash.
for reference, tried the uninstall/install procedue on Macbook Pro using M1 and that worked. Had 1.1.8 (1) installed and it was crashing consistently every time and now seems fine.
I’m running Zwift on a MacBook Pro 13 inch model 2019:
I’ve been running Zwift on it since December 2021 without issues until the 8th of march. It then crashed during workout, just window gone and no error message. The activity up until the crash was logged in the companion app. I also noticed that the timestamps of when you finished a workout plan is not saved anymore. After this I had no crashes until this evening. Again, Zwift suddenly closed and not error message.
Currently I’m on version 1.4.1.
It never crashes during launch but it does during workout.
I got the same bad Image error and I found out that one does not only need to manually delete the Zwift folder in the Documents folder but also the installation folder (after uninstalling) in C:\Program Files(x86)\
Now at least I get the launcher to, well, launch, and download an update.
Please help, I have not been able to use Zwift for a month or so now,
I am getting this error message when I try to launch my Zwift app.
Zwift has encounterd an error and needs to be relaunched. Please restart Zwift and try again. If the problem persists, please contact Zwift Support with the Error code 114 in file /Patcher.cpp at line 554. Would you like to go to Zwift Support now?
It won’t do anything, but if I turn off my Wifi and open it without it trying to update, it works fine, but have to turn wifi back on to launch it without updating.
using Mac Ventura 13.4
@tow_truck_Usmes I’ll reach out to you via DM to get more information and logs from you.
Hey folks, for future reference on the issue that @tow_truck_Usmes was having:
We basically did a clean uninstall/reinstall (instructions) which solved their problem.
Hi there!
I am having this same problem, I go to run zwift and I am able to log-in and click the “lets go” button, it will load for about 30 seconds and then just crashes. I do not get any error messaging and I don’t see any obvious errors in the log files.
I have tried the instructions for reinstalling Zwift posted above with no change. I am on a macbook pro (intel) and Venture 13.4. I have also tried restarting and updating my computer with no change.
When I use the chat feature on the zwift website I am told that developers are working on a fix. Is this a known issues that is currently being worked on or is there an additional solution I should be trying?
