Can't launch Zwift after v 1.25.0 game update [macOS]
Mac version is FUBAR’d.
Have tried killing app and restarting it, restarting Mac and deleting and reinstalling app - none of which allows me to get passed the LET’S GO screen.
Mac has latest software downloaded.
Yep, same issue for me. Launcher not working at all on Mac
(post deleted by author)
We’re looking into this currently.
I’m on a MacBook Pro (M1) OS 12.3.1 and not having issues after update.
Solved:
There would appear to be an additional Updater that needs permission to run. Once this installer runs the program re-launches.
@Christian_Nistri @Shane_Rose and other macOS users:
With this game client version, some macOS users will be prompted to also update the Zwift Launcher app. The dialog looks like this:
It may be possible the dialog box is hidden behind your launcher app, instead of displaying above it like in this image. Would you move / minimize it to see if the “Zwift needs to apply a quick update” dialog is hiding back there?
Also - if other macOS users would confirm this is what’s happening - we’d appreciate you reporting back. TIA.
It’s not working on either of my Macs. I saw that “extra update” window after I restarted my Mac, but it went away, and still nothing launches.
Hi @Iain_Collings welcome to Zwift forums.
Appreciate you weighing in with your experience. I assume that when the dialog box to apply a quick update came up - you did say yes to the update?
When you did - what happened next? Did the launcher app keep showing you different slides like the AAPI Heritage Month image? Did it hang on one image? Did it go away completely?
@shooj @Iain_Collings
It took several relaunches before the dialog box stayed open long enough for me to press the OK button.
The problem was that when I moved the main window to try to find the “extra update window” I moved it down. I didn’t realise it, but that caused the window to be minimised, which made it look like it was either crashing, or going off to do the update. Actually it killed the program. I finally worked out that I had to restart the computer in order to get it to show the “extra update” window again. Then I moved the main window sideways, and it worked. The bummer is that it then said my OS is out of date and Zwift won’t run after August 1st. The computer’s 7 years old and Apple have stopped supporting OS updates. I guess I need a new computer now. :cry:
@Iain_Collings
Thank you for reporting back and letting us know what happened. Sounds like you were able to update both the launcher app and the game app and log in successfully?
You do have until August 1 to use your current Mac. As Zwift runs on iOS / Apple TV / Windows / Android in addition to macOS - many Zwifters will already own a more suitable device to run the game.
For everyone on macOS who can’t log in, here’s the workaround for this dialog box awkwardness:
  1. Download the latest game app + launcher app bundle from zwift.com/downloads
  2. Manually install this package.
  3. Restart your mac and start Zwift .
I CAN log in. But Zwift freezes (scrolls thru the notifications, like AAPI Month) after the “Let’s Go” screen. No dialogue box behind it.
What’s the fix for that?
Mac OS 11.6.4.
P-Sauve try restarting the computer. After I did that, the “extra window” appeared.
Restarting the computer solve the problem for me.
Thanks Iain!
Restart, Relaunch, then that dialogue box also appears, the quick Update, and working. Closed, and works as expected the 2nd time through.
Yep that was the case for me. That pop-up window was hiding behind all of my other windows. Mac OS 12.3.1
The dialog box was hiding behind all other windows. Found it, allowed the update to happen, and the launcher is now working fine. I’m on Mac OS 12.1
