Zwift Cog + Elite Suito T
I have an Elite Suito T trainer and would like to use it with Zwift Cog.
The website states that there is a specific Elite version for this, but it is sold out, and I don’t know if it will be available again.
Do I need this specific variant, or does anyone know where I can buy the “Elite” version?
The purpose of the 18 tooth variant is to support low Watts at a reasonable cadence. Some background:
If that’s important for you, and the 18 tooth Cog isn’t available, you could also consider using a third party single speed conversion kit with 18 teeth or more. Here’s an example that’s compatible with 7-11 speed chains. There are some available that claim 12 speed compatibility as well. I recommend getting one with a steel cog rather than aluminum.
Of course that leaves you without the Click shifter, but if your bike has drop handlebars I recommend getting the Play controllers instead since they do more things.
The cog is also not required for virtual shifting - you could use a normal cassette, unless you need to swap between two bikes with different drivetrain compatibility.
Thank you Paul for your detailed reply.
So when I use the trainer in ERG mode I only need the single speed adapter and I can use my different bikes on one trainer, right?
Only when I want to increase or decrease the power, I have to do it manually in the software?
Yes that will work, but the Suito now supports virtual shifting if you have the latest firmware installed and a virtual shifting device paired (a Click shifter, Play controllers, or the Ride frame).
Ok, thank you!
Is it possible to by the click shifters seperate? Or only together with the Cog?
The Click shifter is only available with the Cog. The Play controllers can be purchased alone (but they only fit on drop handlebars).
Sorry for all the questions…
Is it also possible to replace the 14 tooth chainring with a 18 tooth and use the Cog, so I don’t have to wait for the elite version?
You could, but you need to make sure that the replacement is roughly the same thickness as the Zwift Cog where it interfaces with the freehub body, so if the replacement cog is completely flat (some are, some are not) then you might need to obtain some small freehub spacers to make up the difference. You could probably take the Zwift Cog into a bike shop and get what you need. They could measure the thickness of it with a caliper, tell you the difference between that and whichever third party cog you plan to install, and provide appropriate spacers.
