Compatible Zwift cog
Zwift cog+clik is compatible with the Elite Justo trains with shimano cassette
No. The Cog should fit the Elite freehub if you remove it from the freehub provided by Zwift but the trainer isn’t compatible with virtual shifting in Zwift. You do have the option to use the QZ app as a connection bridge to make the Play controllers work with virtual shifting on your trainer (qzfitness.com)
Muchas gracias por tu respuesta.
Un saludo.
