Zwift Cog from Elite to Wahoo
Hi everyone,
I have a quick compatibility question. I currently own a Wahoo KICKR Core, but I found a Zwift Cog that was originally sold for an Elite trainer.
:backhand_index_pointing_right: Does anyone know if that Elite-specific Zwift Cog will physically fit and work on the KICKR Core? Or do I need the ā€œMulti-Trainer / Shimano HGā€ version of the Cog for it to be compatible?
Thanks in advance for any advice!
It should work if the gear ratio is close to Wahoo’s recommendations which are in this document.
https://support.wahoofitness.com/hc/en-us/articles/16865097915666-Zwift-virtual-shifting-with-Wahoo-smart-trainers
The Cog itself should fit on any 11 speed Hyperglide freehub, which is pretty much all of them that come stock with smart trainers
Hi @Maciek_Marcjasz
Shuji at Zwift HQ here. Yes, The Zwift Cog will physically fit on any trainer that uses a Hyperglide-compatible freehub body. It is like any multi-speed cassette in that regard. You’ll need to remove whatever cassette is on the trainer, and replace it with the Zwift Cog.
To do that you’ll need a Hyperglide lockring wrench and a chain whip tool. Do you own these tools and know how to use them?
FYI - the Elite-specific Zwift Cog has 18 teeth, all others have 14 teeth. This is because Elite trainers have a higher resistance floor than most, and the 18 teeth give you a physical gear ratio that’s a little bit easier to pedal when you want to go easy in game. On other brands, the trainer will adjust to the 18 tooth with a higher virtual gear, so you should have all the resistance you want.
Begs the question if there’s any point to a 14-tooth version? 18-tooth Elite version would effectively be universally usable?
Indeed. The question has been asked. :wink:
A lot of trainers work (and feel) better at higher flywheel speeds. Slowing them down too much can result in a very sluggish and laboured ride experience. I wouldn’t recommend an 18t cog on a Kickr/Core/Victory/Hub/etc.
Then put the chain onto large front chainring?
That works on some setups. However it’s not that simple. A 53 might be a little too big for some trainers and push them outside that ā€˜best working window’. I test flywheel speed in trainer reviews for this very reason. I’m sure there’s at least three people in this world who care for this level of detail in my reviews. :rofl:
And the Zwift Ride doesn’t have a large front chainring.
Interesting, though if it’s really that sensitive, then I don’t know what to say. Certainly the Ride’s chainring is larger than a common 34, or the small chainring on a triple, or a 39 in a 53/39 combo (which your somewhat alluded to). So, really, what’s wrong with 18t being the ā€˜default’?
As above, slowing down flywheels too much can result in a very sluggish and laboured ride experience. This is something I’ve discussed in regard to virtual shifting not being suitable for everyone, even with a 14t and using a 42T chainring.
If Zwift defaulted to the 18t as standard on all trainers - I’d push back hard against this. It would be super convenient from a sales/stock/compatibility perspective. It would NOT be a good move for end users. End user experience is often overlooked, or even ignored, when it comes to commercial convenience.
The bigger picture here is the root cause of the issue - The trainers in question were never designed to be used with virtual shifting. That should in no way have a negative impact any other smart trainer.
I’m not really understanding obviously. Anyone on a virtual trainer but with a regular bike, could choose to use an eg. 50T front chainring and put it on the 11t cog in the rear. But that seems far from what Zwift would recommend. Pretty much the guidance has been to use the small front chainring, which almost always are going to be smaller than the Ride’s 42.
Just for discussion, here’s a gear-inch mini-chart. Is there really a sweet-spot that’s best for virtual shifting? I highlighted the 42/14 ratio as I think that’s what the Ride/Cog combo is, right?
There’s ā€˜close enough’ to get most trainers within their specific best working zone of flywheel speed. The 14t presents problems with Elite trainers, not for others. There’s also two issues at play here 1) trainer capability and 2) ride feel.
I really appreciate the questions / challenges to my comments @Wannie - it’s making me reflect on the why/how/what of my experience with all these trainers to date. I could talk about this all day long… but I’ll have to leave it here for now as I’m heading out for a ride.
Thanks for pitching in Shane, BTW I find the flywheel speed stuff you do really interesting. As virtual shifting becomes even more widespread, the value of that testing increases.
If ā€œsomeoneā€ made a video that summarized gear ratio recommendations for some popular trainers, I would share the heck out of it. It comes up pretty frequently.
From wahoo support:
50T and 18T (from Elite setup)
