Hi all - I’m creating separated thread for the resistance issue in Van Rysel D100 smart trainer, as Zwift Click connection issues with Van Rysel D100 - this thread was about Zwift Cog and Click integration with that trainer, but more and more comments were about other issue, with the same trainer, but with normal cassettes.
Discussion about this issue was also going on on subreddit r/zwift (sorry can’t use links, but you can search for it)
Issue Summary
The Van Rysel D100 smart trainer is experiencing resistance control problems in Zwift’s simulation mode.
Device Details
Trainer Model: Van Rysel D100 (Standard version, not the new “Zwift Edition”)
Current Firmware: 0.106 (from other threads it looks like this issue appeared with 0.104)
Connection Type: Direct to Zwift, bluetooth + external cadence sensor
Affected Mode: Simulation (SIM) mode only
Problem Description
The trainer fails to simulate resistance changes during free rides in Zwift. ERG mode for workouts functions normally, but SIM mode essentially provides no resistance, and no resistance changes.
Technical Analysis
Timing Correlation
The issue emerged approximately one month ago, coinciding with a software update that resolved Zwift Cog and Click compatibility issues. After that there was another software update for the trainer to 0.106 version, that hasn’t fixed the issue. Since then no updates
Behavior Pattern
No resistance changes in Zwift’s simulation mode
ERG mode functions correctly
Resistance simulation works properly in other applications
Working Theory
The problem may be related to virtual shifting implementation. The consistently low resistance suggests the system might be defaulting to the highest virtual cog position. This could be due to Zwift treating the standard D100 and D100 Zwift edition as the same device.
Important Notes
Users with the standard D100 should avoid updating to firmware version 0.106
The issue appears to be a software interaction problem between Zwift and the trainer rather than hardware-related
The problem affects only standard D100 units using regular cassettes
Still only works in ERG mode on workouts. I haven’t seen any firmware updates and no updates from Decathlon support either. And the issue is only in Zwift, other riding platforms work just fine.
Local Decathlon support - they replied that they thought that new firmware resolved all of the issues of D100 (I think they were aware only about D100 Zwift Edition issues). They told me that they will try to contact manufacturer, plus said that I can ofc return trainer (cool but because it’s January there is literally no trainers available in their shops)
Decathlon France - it was the contact that was in OneLap app, no reply whatsoever from them, great support
Zwift Support - they rather think that it’s just my issue and troubleshooting focuses on user error rather than issue on their side. I mean I get it, I was working on tech support long time ago, but I have provided everything in the first message to prove that this is not a single case ehhh.
And the funniest thing from that is that this is only affecting Zwift, other apps are working fine in SIM mode, so I don’t know, kind of looks like more Zwift issue than Van Rysel/Decathlon.
I see new replies from people with same issue on Reddit. I guess no one has it fixed
On the other hand I have also tried to contact Zwift support but it’s so slow, 3-4 days to get response, and when I do I get some basic troubleshooting steps (sigh I was working in tech support for a long time, I know how it is etc) - could you please don’t try to make it as it was just singular case/problem with my hardware? I think I’ve provided enough proof that it is a widespread issue when you have the same circumstances. Why it is not more common? Because people don’t bother to update their trainers when they pick it out of the box - and on the old firmware there are no issues.
But the first message in the thread is specifically saying that it’s not about click&cog but normal cassette. I know that Click and Cog is now working, what happened is that by repairing the issue with it somewhere (either on Zwift or Decathlon side) they have broken resistance control for normal cassette users
It’s insane how there’s no acknowledgement from neither the Zwift community nor the Van Rysel devs. Really considering returning the trainer and cancelling my Zwift subscription as this issue renders useless some of the most significant functionalities.
I will be either returning trainer or just will focus on other platforms as I’m kind of really upset that for that much money per month we receive really no support at all
You guys talking about it here are the Zwift community. Most of the rest of us simply have no experience with that trainer because it’s not one of the popular types. I agree it’s sad that Van Rysel are not responsive. I would return it and get something else. Unfortunately there aren’t any good direct drive trainers at the price of the D100 and it seems the D100 is no exception.
D100 only simulates power too, it doesn’t have an actual power meter. It’s just doing onboard RPMxPower Curve calculations. Getting a trainer with actual power measurements will help in other ways.
Cool but as I said - it was working before, it’s working in other apps. I know that it’s cheapest trainer, but it was working with Zwift and now it’s not.
