What’s the meaning of “result” score/figure in Zwift Power (almost all the way to the right) in the profile page after each race: is that the Racing Score?
It’s ZwiftPower ranking points, not racing score.
Paul -not referring to ranking points, I am referring to “result”… maybe the same thing, but I would like to know for sure not guessing ![]()
Yes the result column is the ranking points you got for that specific event. If it’s one of your 5 best ranked results then it will alter your ZwiftPower race ranking. The gain column should indicate if that happened.
ok, so no racing score…
No but they said it’s coming. Probably not in ZwiftPower if I were to guess since riders are not obligated to use ZwiftPower in order to be scored.
Great point!
There seems to be no correlation between “Result”, “Gain” and “Zwift Racing Score”? The winner will get lowest “Result”. There is a correlation between “Result” and “Race ranking” where low is better, “Race ranking” is avarage of your 5 best results that can be viewed by pressing “Info”-button… But for “Zwift Racing Score” higher is better. It is confusing to have 2 types of ranking, 3 if you also count “Category (Pace Group)”
