Basically, all Zwifters from India will not able to use Zwift sooner or later due to stop on recurring payment guideline issued by RBI. See: moneycontrol. com/news/business/rbi-recurring-payments-norms-a-nightmare-or-an-opportunity-7545371.html
Is there any update on this issue ? Not able to use zwift since october 21
Possibly try using PayPal rather than a bank.
Hello @AdityaRathi
You may have received this message below that was sent to our subscribers based in India. Hopefully this will be helpful to you
Due to a rule mandated by the Reserve Bank of India (RBI), financial institutions now require members to approve recurring automatic payments through debit or credit card. Zwift may see some transactions fail for subscriptions created before October 1, 2021 that are not compliant with the new process.
Some transactions are not being honored by the banks, leading to payment failure for current subscriptions. This will likely be the case for accounts that have not yet been charged this month. Our recommendation is to cancel your current subscription and create a new one.
- If you are currently subscribed or if your payment has failed, please follow the steps in this article to cancel your membership subscription.
- You will not lose any progress, unlocks, or opportunities as a result of this process. As always, it will be safely stored.
- After your membership subscription has been cancelled, \please follow this becoming a member article, to start your new subscription.
According to the new rules, you should be notified by your card issuer or bank to approve the recurring transactions and the new subscription should give us an authorization from your bank that is compliant with the new rule.
If you are still enjoying Zwift while on your current billing cycle, you will not be charged until the previous subscription expires.
If you need additional one-on-one help with your subscription - please use the Contact Us link on support.zwift.com. We handle account & money transactions offline to protect your privacy.
Hi Shuji,
Thanks for your response. Unfortunately I am not able to do anything post adding card details.
It simply don’t go ahead after this step.
Same here. Luckily I had 1 month promo code that came with my Tax Flux. Gonna cancel subscription on 6th December as that’s the end of billing cycle and see what happens by reactivating the service.
Hi Shuji,
I have tried basically at least 3 debit cards and 2 credit cards. The solution you provided did not work either.
Nothing works because of Zwift policy of auto renewing every month without OTP.
In India, since 1st October 2021, unless and until an app requests OTP, I can not pay for it.
Kindly change the policies so that indians will be able to use it.
I will be moving to some other platform due to this tupid process.
Dude, found a workaround. I used Kotak 811 digital debit card for transaction and it worked. Simple open a zero balance account by doing KYC. U need not go to bank, the person will come to ur home. Add say 10000 balance in that account and get kotak 811 virtual debit card. Then u r good to go.
Ketan, a thousand thanks for your tip! I was at my wit’s end after trying multiple times with multiple cards. I got no clarity from Zwift Customer Support, nor from my bank. I had also thought of trying Virtual Cards with HDFC Bank, but they’re not offering Virtual Cards at present for some reason, so that plan had died an premature death. After reading your comment however, I looked up that banks offer Virtual Cards and I finally opened a bank account on my Paytm app - I had to do a painless online KYC, and was issued a Virtual Debit Card instantly. Tried it on Zwift, and Voila! I’m back in, baby! Thanks again for your guidance!
Paytm virtual card worked for me as well. Thanks a ton for posting this suggestion!
Thanks for your email Harshil! Ride on!
- Kshitij
Ride on!
Thanks Ketan, I see alot of positive feedback here on virtual cards.
I would try that for sure
