I’m “glad” other people are reporting these problems because I’ve had to abandon my use of the ZC bridge (Android smartphone) since it started giving me big problems on 28/02/2022. Again, like you, it had been working OK prior to this date on the exact-same set-up. Maybe it’s something specific between Zwift and Android that changed during the recent app updates?
Thanks mate.
After trying lots of things these steps worked for me.
I realized every time I connect my Tacx Flux S to the Tacx Training app on my phone I have the No Signal on my PC.
However, if I follow these steps it works fine again:
Unpair trainer in Zwift program (desktop version)
Unpair trainer on pc, laptop in Bluetooth settings on your pc, laptop
Also facing this issue on Windows 11 + Saris Hammer H3. Still on the trial and was hoping it would be a lot easier to get started, not sure I want to spend money on something I have to fight to get working (getting myself onto the trainer already requires enough willpower!). Wahoo RGT seems to work fine with the same setup.
I pair using Bluetooth. As others have seen, it connects under Power, Cadence, and Controllable, but after a couple seconds “No Signal” shows up. Have tried power cycling the trainer and closing/reopening Zwift.
I had these ‘no signal’ errors when I first starting using zwift in 2020. The error went away for nearly two years, and now it’s back. Looks like an app update broke it again Using Huawei Honor 9 and Panobike cadence/speed sensor.
Had tried everything ( updating and reinstalling app, toggling Bluetooth and aeroplane mode, unpairing, new batteries, restarts…) until I tried this suggestion and worked for me first time - aeroplane mode on / start zwift / aeroplane mode off. Cheers!
Seems to be getting worse. The flight mode trick has stopped working, and took half an hour to pair yesterday. I spend more time trying to pair the sensors than I do using the app. This is getting very tedious, on the verge of cancelling my subscription and finding abother platform.
I have a small desk fan on while I’m training, but that can’t be it. I have bluetooth speakers, HR monitors and other devices connected no problem at all. Panobike sensor + Zwift = garanteed issues.
Yep, tried that. It’s a known issue in Zwift. Like most people I have many bluetooth devices connected simultaeneously, without a problem. The BT speaker isn’t used when I’m on Zwift, have tried turning HR monitor off when pairing Panobike sensor, makes no difference.
One other thing I thought of, remove the permissions for the Zwift app. Then when you get to the pairing screen Zwift will ask you permission select this time only.
Hi - this issue has just started for me tonight, after 3 years of Zwifting. All hard/soft ware has worked fine until now. I’m on a new Macbook Air which has worked previously. Have tried connecting via the companion app too, which normally works, with no success. This thread is two years old, so has anyone identified the problem and found a fix?
I’ve tried a new Zwift install, but that doesn’t work.
Same issue here. Windows 11, iPhone 13, Zwift Hub trainer. Works intermittently, but I have yet to finish a ride before it disconnects me. Is there a support number for Zwift?
