Any tech heads have any idea what zwift graphics would likely be produced with the a19 chip and 8gb ram. Looks like they are the specs of the new one.
You should assume nothing until Zwift gets their hands on the device and tries it. There are some graphics improvements that have been applied to Apple mobile devices with the A18 chip (and better) so that’s promising, but it’s not a reason to buy the new Apple TV with any firm expectation that a better profile will be applied. Believe it when it happens.
Likely depends on still supporting old AppleTV versions. I’m more curious about the Bluetooth channel limitation lifting myself
So Apple announced its new AppleTV today.
- I can’t find if it supports more than 2 bluetooth connections (be nice not to have to use the companion app all the time)
- any planned Zwift benefits to upgrading? Its a steep price lift at $299.
Apple has not shared any information about the Bluetooth connection limit as far as I can tell.
For now there are no real benefits for Zwift. Quicker CPU will probably make it feel a bit snappier navigating menus and such, though it does depend on what you are upgrading from.
Do not buy it with some expectation of future improvement for Zwift. Just wait and see what shakes out, and then decide.
I had an AppleTV 3rd Gen that I used exclusively for Zwift. When Apple released the 4th gen AppleTV, I went out and bought it for use with Zwift on the hopes it would get better graphics.
After more than a year of waiting, I decided to do a dedicated Windows computer with really good graphics card.
I’ve since moved on from Windows and now use a MacMini M2.
What is the m2 like?
Surely a faster chip and better ram would show a big improvement in graphics.
No it will not unless Zwift tests it and decides that increasing the graphics profile is a good idea. It could happen, but absolutely do not buy it with an assumption that it will happen. For now assume no change and make your buying decision accordingly.
I can only say for M2 MacBook Air 15”, it runs Zwift fine.
The current generation Mac Mini will run rings around it and that’s probably the better option, the M2 laptop is 3 years old now, but it is still reliable.
My normal Zwift computer is the M4 Pro Mac Mini - this works very well. If needed I can also use it for work, it is very quick - it even runs my two 6K screens.
MacMini M2 is really good.
I bought it discounted a few months before the MacMini M4 came out.
M1 and M2 CPUs (not the Pro version) get the High graphics profile in Zwift. M1 Pro, M2 Pro, and M3 or higher CPUs get the Ultra graphics profile in Zwift. They’re all good systems for running Zwift.
In the Mac Mini line, there never was an M1 Pro CPU offered, but there was an M2 Pro CPU model.
So the m2 pro Mac mini offers ultimate ?
Yes Ultra profile is supported on all of the “Pro” model Apple Silicon CPUs
Here’s a report from TrainerDX that someone submitted:
My old MacBook Pro with the M1 Pro CPU also got the Ultra graphics profile in Zwift.
The only problem with the M2 Pro Mac Mini is they’re not very common.
To my eyes, there is not a huge difference between the High profile and Ultra. I notice the resolution difference more. But someone whose eyes are trained on popular games (ie, not Zwift) they may notice it more.
I would say check out Apple refurbished to see if they have an M4 or M4 Pro, otherwise you are probably best going with a new M6 Mac Mini which seems to be very fast.
It’s about AUD$1449, that’s not inexpensive, but prices have gone up a lot recently.
At least you can get AppleCare+ with it. If you are studying maybe you can get education discount, that should reduce the price a little bit.
I looked up iPowerresale (another vendor I’ve used before who are okay) and their Mac Mini M4 prices were not very attractive, barely any better than a new M6 direct from Apple so you may as well just go brand new and get the AppleCare+ with it for peace of mind.
For that price I was really hoping for the A19Pro chip with the 5 core GPU. As it is we’ve got the hobbled 4 core GPU which while is much better than the A15 isn’t the graphics powerhouse we were promised.
I’ll leave it for people like DCRainmaker & GPlama to test first, and well as Zwift HQ to see if the enhanced GPU raises the bar for in game graphics.
If it does then I’ll consider upgrading, otherwise I may shop around for a deal on an M4 mac mini instead and do what DesFit does.
What you say is correct for those running MacOS. An important distinction, iPads M1 - M5 all run Basic profile with a 30fps cap and limited resolution. The mobile app (also runs on iOS, tvOS, Android) does not have access to higher graphical modes
They have said that the graphics vary with some of the higher end iPads. I see you were present in this topic as well:
But exactly what that means is unclear. The name of the profile does not always tell you what you get. For example for a long time Intel Macs on the High profile had no shadows, so what do we call that? Looked a lot like Basic. I have seen log reports from a few modern Android tablets that are getting much more than 30 FPS, but an M5 iPad is apparently still capped at 30 FPS.
Short answer, I would not be surprised to see another release note that says the new Apple TV got some improvements in graphics quality, but there is unlikely to be any explanation of what that means and I have no idea if it will be a noticeable improvement.
I don’t think ATV will get enhanced graphics anytime soon as it’s OS is TVOS not MACOS so it will just get the same graphics profile as the current model. I don’t see any upgrade benefit as yet.
Don’t expect a graphics update. I think all TVOS only gets medium profile. I wouldn’t expect that to change
