New 2026 AppleTV
It’s not Medium, it’s Basic with some extra bits - shadows are one extra, I think (though I could be wrong), and the menus and HUD (but not the world) are in a higher resolution on the 4K models.
Given the current model, A15, would still be quite capable for having a higher profile other than basic, and been waiting years for Zwift to address that, I wouldn’t hold my breath or even bother upgrading until there was a concrete implemented change
Gplama messaged me saying he had an ATV on order and will look at it. Surely has to come up to avail of high end graphics.
I currently have a Macbook Neo. Zwift uses the profile that runs well at 60 fps in high settings. The Neo uses the A18 pro chip. I would assume that the new AppleTV will support the same “high profile” settings with the A19 chip, but we know when it comes to Zwift it’s a see it to believe it sort of thing. On paper I would still give the new AppleTV a chance as a great price option for the potential “high profile” settings at 60 fps. It’s certainly capable. It’d be a great set up for the money if that’s the graphical settings you care about!
It won’t because the OS and construction of the device is the driver. Neo will use MacOS. ATV and iPads have a different operating system. My M6 MAC Mini runs ultra my M5 iPad Pro runs basic with a few enhancements. The A19 Chip may be capable but the OS is the limiter that zwift haven’t addressed. It’s also I believe due to the fact that ATV and IPads are fanless. So if they got the ultra profile running into areas of high cpu or gpu usage you’d get thermal throttling as the devices don’t have fans to cool them. I wouldn’t hold your breath because it’s not the chip that is the determining factor.
On the topic of thermals, it should be noted that even my M4 Pro Mac Mini gets pretty damn hot at times. :exploding_head: Sometimes I will put it back to a lower graphics setting.
Although they might be discontinued, those big Mac Pro towers (2019 and 2023) can be run flat out for hours and hours non-stop and they never run hot. They had massive cooling overkill. I sometimes run Zwift on a dual W6800X Duo Mac Pro and it treats it like nothing is happening.
The powerful, compact devices are amazing, but there is a trade off.
I’ve never used a Mac or IPad for Zwift - is the graphics that much of an upgrade from Apple TV?
Most of the modern Macs with an Apple Silicon CPU can run Zwift in 4K resolution at a much higher graphics profile than Apple TV. There are shadows, lighting effects, sharper images, faster screen refresh. Whether this is enough for you to care about spending the money is hard to say. It matters to me, but not everyone cares about the difference and that is OK, no shade on anyone who is satisfied with something less. Apple TV is low cost, low resolution, low frame rate, low graphics profile, no custom workout creator, no access to log files or activity files if something goes wrong. The iPad is a different story. It has a few of the benefits but if you buy one of the high end models it ends up costing similar money to a Mac but doesn’t deliver all of the benefits. The lower end models are more like Apple TV in terms of the graphics.
Will there be an improved graphics profile for the new Apple TV releasing next month with the A19 chip?
Nobody knows
From Apple TV, huge difference with the Mac. It’s a real computer. Resolution is much higher and it looks vastly better. And it can do a lot of other things.
Highly unlikely. Zwift fot ATV is a different operating system and doesn’t have a fan to remove heat buildup. The chip is capable but the hardware probably isn’t. I wouldn’t expect it. ATV with high or ultra graphics would be fantastic.
That’s not really it. iPhone and iPad also have no fans for cooling, yet they run a much higher graphics profile in Zwift. In fact, Zwift has already updated the graphic profiles for newer models of certain iPhones and iPads, allowing them to leverage their modern hardware—even though they are completely fanless.
The limitation on Apple TV isn’t cooling — it’s that tvOS uses a completely different Zwift build that is artificially locked to a lower graphics profile. If enough people keep asking for an updated profile on the new Apple TV, Zwift might finally bump it up…
They don’t have a “much higher” graphics profile than ATV. They have some enhanced features like shadows and your avatar renders betters. But the world around you is still basic profile. ATV may get these with the new chip and increased ram but will probably still be on the basic 30 fps profile the iPads get. I do think zwift could increase the graphics profile with today’s chips and increased ram but it doesn’t seem imminent.
My new Apple TV has arrived – but I can’t press the sign-in button. :neutral_face:
EDIT: It’s working now. I had to set the resolution to a fixed value. The BT limitation is the same as in the previous version.
So expensive, even used from eBay. I’m going to sit tight with my AppleTV box until something comes out with advantages I can’t pass up. .Maybe a way to utilize more Bluetooth devices than just two? It’s a pain having to use Zwift Companion every time.
The BT limitation is most likely hardcoded in Zwift to pop the prompt to use the Companion app if you attempt to connect >2 BLE devices. So there’s still hope!
Hopefully we’ll know early next week what the capabilities of the ATV4K '26 are when the devs have had a chance to test the hardware.
I got mine yesterday to replace an aging non 4K ATV unit with the glass remote. It really struggled when in big races, the loading menu took forever and it would quite often crash.
New ATV is amazing in comparison, boots super quickly, loading screens are pretty much non existent (it only had enough time to show one bit of text). Graphics look noticeably smoother and better, text is crisper and easier to read (4K TV).
There’s probably not too much difference between this and the older 4K ATV model but for me it feels like a massive upgrade.
Can you see in the settings if it allows higher resolution than 1080p for Zwift Video?
The 4th gen appletv 4k with the a19 chip only provides 720p resolution as of this morning 7/14. Looks like the dev team has some integration work to do.
