Greetings, does anyone know how to do multiple routes on the same course? If I want to ride in Watopia, for instance, and I want to ride for 2.5 hours of medium to easy riding, is there a way of programming that in somewhere? I could pull up all the routes and try to figure it out but is there a more efficient way? Maybe in the Workout area? I don’t know, just asking.
TIA,
Larry
No.
The easiest way is to do manual turns. You can start of by selecting a really long route and from there do manual turns.
you can use this map to help you navigate.
Sooner:
There are longer routes available in Watopia even without manual turns. If you select one of those you can do 2.5 hours of medium to easy riding with Zwift making all the turns for you.
Thanks, I see that but just thought I might be able to set a course ahead of time… oh well… not yet!
Thanks again!
Larry
Thank You. I figured that but was looking for a set plan I could create. Oh well…
Larry
A_cid
(A)
October 20, 2019, 9:34pm
6
It would be possible if you the customer would have the function to create your own route.
Now you are not the first and many many before you requested this feature but as you can see … you can’t see nothing other than still praying that this feature like many other will be implemented in the next thousand years:
Similar to Strava segments, Zwift should have a route creator. Many of us who do a lot of group rides, workouts and races get pretty bored with the same few routes.
The route creator can be implemented in one of two ways (or both). The rider can simply create a route based on a previous ride (lik…
This might be a stretch, but here is an idea:
It would be very cool to have a “simple” environment to create your own course. For example, you could create a custom route in Strava, and load it into Zwift so that you could virtually ride the course’s elevation and distance (with a visual component…
While this idea has been suggested before - now with the many options of the NYC course, even selecting the “Everything Bagel” route there are three segments missing one never gets to ride. If I could create my own route - I could create an “All Roads NYC” course that I bet 90% of the Zwift paying …
Hi, I have seen that many posts on this topic have been archived with the new forum, hence this new post.
I would like to be able to create custom routes, so I can follow them during my Zwift Sessions. Here are the current limitations I see so far:
When riding long distance on a course (2h-4h se…
I would like to suggest that there be an option to allow us to create our own routes in the worlds that are presented to us for that day.
This would allow the dev’s to make the map, and the path, but people can choose which routes and elevations that WE want to take.
With this option you can have …
Is there a function in Zwift where you can pick multiple routes at the commencement of your ride?
A lot of riders seem to ride more km’s than the first route they have selected and this is evident in the new world like NYC(The longest route is 34km). This would save you from manually doing this onc…
Ability to change starting point. To create critical mass, we are limited to the map we ride, but could we have a way to change the starting point on the map? I feel that it could create a bit more flexibility.
