Hello, I installed a new justo 2 with cog today. Unfortunately, virtual shifting isn’t working. I get the error message “The trainer doesn’t support virtual shifting. The latest firmware (no. 36) is installed.” I’m at a loss. Does anyone have any idea what could be causing this?
Similar report with an Elite Avanti over here
First I would make sure you are not using ANT+ (remove the adapter if you are using it) and try re-installing the app according to these instructions. Re-Installing Zwift
tried everything but unfortunately without success
Is your trainer connected via Wifi or Bluetooth? If via Wifi, try Bluetooth instead.
is only via bluetooth connected
I had a similar problem when I set up my Suito with Click V2. Resetting preferences worked for me.
Unfortunately, nothing worked for me. I reinstalled it on an iPad, a MacBook, and even a new Windows PC. Unfortunately, it doesn’t work for any of them.
Hi @Marco_Bue,
Thank you for posting. I am Nelson from Zwift Support.
Thank you for following the steps suggested by @Stephen_Metcalfe and @Wannie. I would appreciate it if you could do a full reset of the trainer via the Elite Upgrado app, then re-pair everything from scratch in Zwift. Make sure to have the Zwift app running on only one device at a time and to have your trainer listed under “Resistance” and the Zwift Click paired under “Controls”.
Do not hesitate to contact us at Zwift Support if you need further assistance, and we will be there for you.
I’ve now manually reinstalled the firmware via upgrado (emailed to me by Elite). Now virtual shifting works.
Hi Marco,
I’m facing the same issue as you!
Could you tell me which firmware version you manually installed most recently ?
Did Elite provide you with a .hex file or a .json file ?
I have contacted them, but it has been difficult to get useful information…
Thanks in advance!
Hello Mike,
It was a json-file. Update 3.15
Hello Mike,
I just ran into the same issue and completed a first ride without shifting
. However, good news in my case. Got it to work.
In the end what made it work for me was to disable Wi-fi and re-start the Elite Justo 2.
Before that I did the usual stuff:
1/ upgrade the Justo 2 to version 36 over Wi-Fi with the upgrado app
2/ upgrade the Zwift controllers through the Zwift companion app
I kept getting the pop-up that virtual shifting was not supported by the smart trainer.
Solution for me: Disable Wi-Fi (forget Wi-fi in the myEtraining app). After that re-powered the Justo and tried a Zwift ride. Success!
Of course with that you disable the automatic updates. So, it does not look like a good permament fix.
Hope it works for you.
Cheers,
Diederik
Hello Marco.
Thank you for your response!
I am surprised by version 3.15 because on my Justo2 hometrainer, the Upgrado app shows a current version 36 and a possible update to version 37 (although the automatic update via WiFi does not work in my case
On your side, do you confirm the Upgrado app reports a version 315 or 3.15 for your Justo 2 home trainer?
The Elite support just explained me that the trainer cannot be updated manually… So I didn’t receive any json file from them…![]()
Could you send me your JSON file ? Thank you in advance.
Thank you, Diederik, for these tips!
I tried removing the Wi-Fi settings in the myEtraining app, powering the Justo 2 off and on again, and then starting a Zwift ride. Unfortunately, virtual shifting still doesn’t work. ![]()
I also tried uninstalling and reinstalling Zwift, without success.
I’m really disappointed with this Justo 2 product.
Thank you for your support anyway.
Sorry, I made a mistake. It was 37, of course. Elite then sent me version 36, and it worked after updating to 37. I have the file, but I can only provide it without guarantee.
Hello Marco.
I’m interested in the json file. I realize it cannot be guaranteed and I will try to solve my problem with Elite. I will only use it as a last resort.
I’d be happy to give it to you, but I don’t want to post the file here. How can I send it to you?
I sent them to you ![]()
After dozens of attempts (with different Wi-Fi networks, etc.) the automatic update worked with the Auto Update button in grey in the Wi-Fi settings presented by the myETraining app (Android version)… ![]()
My (bad) impression was that grey = OFF and white = ON, meaning the option is activated.
So the Justo2 home trainer didn’t support virtual shifting with those versions:
- firmware revision: 36
- software revision: 15
After the auto update, the versions are
- firmware revision: 37
- software revision: 37
and the virtual shifting works in Zwift … Alleluia !! ![]()
Hope it may help other users.
I Am not able to update to 37 from 36. I am useing ios. But is blinking like downloading. Next start installing is not working….
“fter the auto update, the versions are
and the virtual shifting works in Zwift … Alleluia !!”
do you using wifi as connection in zwift or bluetooth?
