Heart Rate Monitor No Longer Pairs After Update
Same issue here with Wahoo TICKR connecting via bluetooth.
When I open the Trainer Road app with the IDENTICAL setup it works. But when I open Zwift it shows no signal after connecting. TACX Flow turbo usually works ok, not always though.
HRM works with phone and watch etc ok via bluetooth and with bike computer via Ant+.
…its just Zwift App.
are you trying to pair it to lots of different devices or apps at once? bluetooth is a 1 to 1 connection so make sure you exit and close all other apps and that the heart rate monitor isn’t connected to any other devices (watch etc)via bluetooth when trying to use it for zwift
Pretty sure only one at a time, but i will double check that nothing was connected unknown to me.
However, if this was the case and it was connected to my phone accidentally, it wouldn’t have worked on Trainer Road either.
Literally open Zwift, doesn’t work, close zwift, open TR, works, close TR open Zwift, doesn’t work. All through the same setup.
Have just bought an ANT+ usb dongle which it does connect to, but is displaying a BPM of about double the actual so that hasn’t helped much lol!
I have used both the integral laptop bluetooth and a Bluegiga BLED112 dongle (which was required for TR functionality). Same result from both.
Steve
I too have the same issue,
I connect Wahoo Kickr core via bluetooth and connect Heart Monitor soon after connection the HR will read no Signal,
I am isolated in a garage with no other bluetooth devices except for Kickr Laptop and Garmin HR .
its getting Frustrating now…
I’m lucky I have a Ant+ Dongle which I eventually use to connect my HR.
Ric.
I had the same problems (Power and heart rates devices displayed as connected vua bluetooth but no data registered).
In fact it seems that, even though zwift was displaying “connected”, it was not.
I went to the bluetooth connectivity of my laptop, erased every device (assioma pedals and heart monitor) and connected them back.
Then connected them on zwift again and, miracle, they were detected/connected and did send data this time.
I hope this will help other zwifters.
Ride ooooonnnnnnn!
Basile
you shouldn’t connect your devices to your PC/laptop this will stop zwift pairing with them.
just open zwift and pair it there
