Halloween is soon.. where can I get the costume?
The climb HUD ālook the wrong wayā issue still exists on Triple Flat Loops leaving the desert where the split to either go up titans or down to the tunnel is.
I got the update and I can no longer connect my computrainer through a usb connection. Yes, Iām old school and have been using zwift for some ~10 years. Iāve restarted the computer and the trainer, unconnected and reconnected to the computer (Windows) but it will not connect. Iāve never had this happen before.
Hi, Since updating to this release (and doing a second login thing), Iām getting an instant crash/application close when i finish a ride and try to change the name of the session/workout.
I am running Zwift on my older mac, so it could be that thereās no support for that OS now (12.7.6) but thought iād let you know in case itās happening to others.
(It does save the majority of the ride, but depends where it is in that 10minute update to server window).
Thanks ![]()
Monterey is still supported by Zwift
I saw this issue on Sugar Cookie as well.
Since update I have kind of lagging each 3 pedal strokes very annoying. I am on Apple TV No issues with WiFi connected via companion ( iPhone )
Can I do something to have it smooth again please ? Thanks
What kind of lagging do you mean?
Do you always force-close Zwift with the remote after every time you use it? If you leave it constantly running in the background then you can get various weird issues.
Screen freeze for a second each 4 seconds
Go-stop - go - stop
All zwifters around me same , when i look to borders road you see clearly stops ;-(
I have taken some movies too
And yes already restarted all windows no change
Iām not sure what you mean when you say ārestarted all windowsā.
Have you tried rebooting your Apple TV? So a proper restart from the System section of the Settings app, not just restarting it from sleep. It sounds like something is quite wrong on your end.
Hi
Ever since this new update, i have not been able to select an the alternative power source that i have used for years now. Essentially it is a device called a Cable utility and it takes ANT from my power cranks and converts to bluetooth. I use it for accuracy and consistency. I still use my TACX as the resistance source.
Has something changed that disallows this?
Keeps crashing when editing workouts on the app. Windows 11.
Thereās a thread on this issue on Macs. So you might like to join in there.
Thank you!
Windows and Mac users please note.
Windows and Mac users please update at your earliest convenience.
Found this gem this morning after the update. How can I stop the pop up if I hit the button on the Play controllers?
donāt hit the button and it will stop ![]()
