Game update v 1.98 [September 2025]
I’ll try again today, but seems rather odd having the need to restart it multiple times to activate? One would have though, that installing the updated via App Store, then starting Zwift it would be there…
It’s not ideal, but that’s how they said it works…
Half actually. But you could have a hard ramp interval and it’ll get half the xp that a block at 35% of FTP will get.
All ramps score the same was my point, that needs to change, they should be based on effort or score them the same as steady state blocks.
Experienced a bug with the mini map after updating on my iPad.
I joined a group ride late and the mini map continued to show some of the Macaron route while I was climbing Ven Top. Note that I joined sometime after the other riders had completed the Macaron bit.
Just as an FYI, not sure if others experienced it, but steering in the WTRL TTT was different this morning post-update. Multiple instances of riders, who had steering enabled but were not steering (which is how we typically ride), not auto-seeking the draft.
Could be related to the TT bike steering changes mentioned in the patch notes.
Thank you!
After deleting and reinstalling on the Mac it gave the network permission pop up and now all is working.
Thank you for posting back that it worked.
For wildly varying power meter readings, may I suggest also have them calibrate, then if needed also check or replace their power meter’s batteries.
Where can I get a stuffed Scotty?
they had them made for the winners of the Tour de France Femmes stages… we know they exist!!!
You probably need to break into Zwift HQ
Having issues with my cadence not registering since the software update on Apple TV. Nothing else in my setup has changed.
Is there a way to not earn a jersey whilst in coffee break mode? I noticed if riders are in a large coffee break group and complete a climb or sprint they obtain the jersey but it sets the record speed/time too high for non-coffee Break riders.
This will be very expensive :chipmunk:
Doesn’t look like that would fit easily in the back jersey pocket.
No there is no way to avoid that. You can even get the 1 hour Alpe badge at like 1W/kg in a banded ride if the rest of the group is strong enough.
Absolutely!!!
Are you in??? :rofl::rofl::rofl::rofl:
GCN has one in the back drop on the set!
I used to be able to finish rides without my phone battery being drained even while plugged into the charger. What’s causing the huge drain?
