Will this also fix the White Tron:
I believe the white Tron bike is still being worked.
Thanks.
Although the white Tron look Fast! ![]()
I second that Cindy ![]()
We need to start a petition to bring back the White Tron Deer!!!
I got a meetup every monday and the meetup bottom goes away and comes back all the time, until there is 5min back.
Does anyone els have this problem?
We used to have ghost riders, why not ghost deer?
Expecto Patronum!
And still no support for Wahooās Direct Connect. @Wes @shuji - my previous questions regarding this were completely ignored. When can we see progress on this?!
I liked the white deer
What about the issue at the top of the Alpe De zwift?
Nothing on fixing event joining so that people racing ZRL donāt have a massive waste of time and effort?
This is not internet problem because i can see my bike on the road, the power, kilometersā¦because blob diseappeared, no draft so I lose speed (2 or 3 km/h) and than when blob appears againā¦dropped.
Iām not the only one to have this problem and others Zwifter I asked, have the same bug.
Dā¦F
Any idea when the new routes wil be added to the Companion App for creating MeetUps?
Zwift doesnāt need an internet connection for you to ride through the scenery. Once youāre in a game world, you can disconnect from the internet and ride perfectly well for as long as you like, just with no other riders.
Theyāre already there now.
You can ride Zwift completely disconnected from the internet and you will get exactly what you are describing. The only time you actually need to be connected is when you are logging in, and when exiting (if you want to save your ride). Once you spawn in the game you can disconnect from the internet and everything will function normally, except that you will be alone.
This defiantly sounds like an internet connection issue. You can see all that if you start Zwift and then disconnect from the internet.
Have you tried restarting your router and modem?
Powerups have stopped working for me. On a Tron bike (not TT) while doing the new route Twilight Harbor. The powerup pops up and disappears after milliseconds, canā activate it through the space bar nor the Companion appā¦
On a macOS if that matters.
Edit: Some more information for debugging: It might happen only on a specific segment. This was on the Tower Sprint.
Iām sure there was no ā+40 XPā or something like that, it landed on a PU and disappeared right after without being used/applied. It happened again on next lap. The Companion app showed the PU, but hitting it didnāt do anything, and the game itself did not show the PU more than for a few millisecondsā¦
Other issues Iāve noticed after the new update (some might be old issues, though, I canāt know for sure):
- During the TdZ event (Stage 1, Short Ride/C) in Two Village Loop, the rider list on the right showed 0:00 as distance to the riders ahead, even when they were a hundred meters up the road.
- The leaderboards on the left sometimes showed weird times, such as ā:00ā (only seconds, while the minutes were missing).
This is likely a connection problem, more specifically connection ping. ZWIFT recommends ping of less than 50ms. Anything greater than that may cause connection to drop off sooner or later. Ping can be tested on speedtest.
