Game Update 1.18 - October 20th, 2021
I went back two releases on my Kickr Core. ITs working perfectly now.
After update, ive got approx 20 more FPS but all riders, including myself blinks/flashes stochastically.
Run on Windows pc 1080 resolution.
No issues using android
Only me?
This is because you’re now using the latest launcher/installer. See this workaround: New launcher (1.0.51) causing stutter on Windows systems - #49 by Dave_ZPCMR
My Zwift cant connect (my phone bluetoorh) to my Magene bike trainer after last update. anyone can help me?
They will probably need more info about the set up you are using.
Noticed tonight that the Back button on the pause screen has a massive white box around it when you hover over it with the mouse. This is on PC, and no other button reacts like this (like normal). If I had to guess, I’d say I’m seeing part of an exaggerated interface intended for Apple TV. This unexpected and presumably unintended crossover may be the reason for some other weird UI things, like the missing scroll bar.
vid
Streamable Video
Using Android v11 with a Wahoo Kickr af18: updated to the latest 10/22 version through the Play store.
I can no longer connect to any device via Bluetooth. It won’t find my trainer, cadence sensors or wahoo HR monitor.
(I know everything works just fine because my bf runs the same equipment on his iPhone)
Will there be a patch released? I tried uninstalling everything, uninstalling just the update - but it won’t find anything via Bluetooth through the Zwift app.
I had this same issue last night on Android. Running Zwift on my new Samsung 21 Ultra, which has been running Zwift without issue for a month until the update. Did the Mountain Route for the first time, and Zwift crashed on saving so hard that my phone rebooted. When I got Zwift running again, it offered to resume my route, which was about 1km short of where I had stopped before. Without moving, the Route Report showed I had ridden the entire course, so I saved the resumed ride without moving. I had taken a screenshot of the ā€œroute completedā€ banner using my phone itself (since the Android client won’t let you use Zwift for a screenshot of route completed or level level/item unlock banners). I re-entered the game, and Mountain Route was now checked off as being done. I checked the experience points gained, those calculated out correctly (I keep a log of xp and Drops gained each ride). But instead of the 43,000+ Drops gain shown on my route banner screenshot, I got 197 Drops. Not 1,970. Not 19,700. Just 197. Incredibly frustrating.
The night before, I was unable to complete the Innsbrukring with about 1km left because Zwift suddenly lost the ability to see my trainer in Bluetooth. I’d reconnect using Zwift, but it would only stay connected for several seconds, then lose connection again. That was immediately after I had completed the Dempsey Challenge, which I attempted to ride out to a full kilometer after the finish line for the 20xp, but the Bluetooth connection failed then too, and I could not keep it connected. I rebooted and reconnected my phone before doing the Innsbrukring, thinking it may be a hardware issues (odd that an issue would crop up after a month of perfect connections, but you never know). But Zwift lost the Bluetooth connection again. I tried connecting other Bluetooth devices, which worked without a problem. Another issue that literally never had happened until this update. I’ve been updating Zwift, and believe both of these happened using version 1.18.1.
Updated my ATV after asking some club friends if they had any issues. They said all was okay so I updated.
• No spanner in the pairing screen to let me calibrate.
• No ability to choose a world in which to ride.
• No in-ride join event button bottom left, only the timer and description of the event.
• No rider names in right-hand list as if no internet but rider names were attached to riders.
• Pause Menu was only half visible with 50% off the screen. The pairing button was okay visible but half the button missing.
Normally I seem to avoid most of the bugs but not this time!
On the bright side I could U-turn.
In latest update, while In watopia, am unable to make a u turn. Once I hit the uturn button on screen, avatar doesn’t turn and then bike speed will not go above 15 mph no matter how hard I pedal.
For now i am gonna ride with Bkool and wait when Zwift is fixed.
Just wondering why Zwift isn’t fix this 1.18 version with older 1.17 version what make this app work better. Just name 1.17 version with a different name like 1.18.2. I assume that Zwift is backup that older versio.
A post was merged into an existing topic: Route selection scroll bar missing on Windows [October 2021] [1.18.0]
Hello, today (October 27) I’ve noticed something unusual : I can go to drop shop, choose frame or wheel set that I don’t own and I can ride with this setup without buying it… This frame only available at level 35, and these wheels at level 20, while my level is 18…
It’s a bug created in the latest update. See the following thread on this subject: Drop shop bug after 1.18.0 update
You don’t get to keep these items in your garage for future use, apparently.
Hi, I’m using a JetBlack volt turbo direct drive.
Since the update, erg mode won’t engage. Then it will but 15 watts lower but won’t increase as the workout increases.
Every so often it then ā€œgrabsā€ at 300/500 watts.
I am having the same issue although I use appletv and connect via companion app. With one update I get tons of drop outs, the next update seems to fix and it’s stable again, then another update and it’s dropping out again. Gets very de-motivating to join a ride or race d/t the drop outs
After nearly a year of no connectivity problems I’ve now hit them with my MacBook Air. The latest versions of Zwift 1.18.0 and 1.18.1 no longer connect to my Wattbike and Garmin heart rate monitor via bluetooth in the initial start up screens, despite the bluetooth devices being visible with the native bluetooth system settings on the MacBook.
Strangely I’ve found if I bypass the initial device connection screen in Zwift and watch another Zwifter instead, then hit the ā€˜return to me’ button the wattbike and HR monitor are suddenly connected.
I’ve run the same bike and HR monitor on an iPad and iPhone via bluetooth with no issues.
Anyone else having similar issues?
David
Setup:
Wattbike Atom NG
MacBook Air 2019, macOS 11.6
Garmin HRM-Dual
Having this same issue. Anything change for you?
