Hi! For the last 3-4 days, I can’t train with ERG. It is first enabled, then my avatar stops pedaling and ERG disengages. I keep pedaling and ERG tries to engage again but it keeps disengaging. I can train without ERG though. Does anyone have the same problem?
Thanks!
Which trainer? How is it paired? What are you running the game on?
I have a Wahoo Kickr. I have the latest game version I believe (1.51.0). Paired with my Macbook (bluetooth). I also switched to my iPhone but same problem. Thanks Paul!
Test it in an ERG mode workout in the Wahoo Fitness app. If that fails then you need support from Wahoo. When you are free riding, do you feel resistance changes from the trainer that coincide with the terrain? (Wondering if the controllable pairing is getting interrupted.) I also keep an ANT+ dongle for my mac ($20) that I mostly use for troubleshooting occasional Bluetooth issues. I would suspect Bluetooth interference, except it doesn’t make sense that it would work any better when you’re not using ERG mode.
I had this occur the other day. I adjusted the bias from the companion app during a workout. Then ERG mode would not reengage. Tapping on the incline button showed it switch to ERG mode but it would immediately switch back to incline. I’m on a Zwift Hub paired through the companion app on an Android phone. Zwift is running on a PC.
Many people with the same problem, on many different devices and trainers. The bug is in Zwift (it gets stuck in incline mode), not in the trainer firmware. It happens when you stop pedaling and ERG disengages. Switching to the next interval or restarting the workout will cause ERG to work again.
This is the expected behavior. If you stop pedaling the game will presume you are unable to continue the workout abd release erg mode. If you want/need to stop pedaling for some reason you should just pause the workout, and then un-pause when you’re ready to go again.
Sometimes things happen that are out of your control, such as power drop outs (as op experienced) or an accident like spilling your water, and you do not have the ability to pause the workout in time. It’s been introduced in the last 6 months as re-enabling ERG mid interval used to work fine. What’s more is, if you’re doing repetition sets, it doesn’t re-enable when the next interval starts but when the entire set finishes.
