ZwiftPower not updating power correctly
For the last month or so, most group rides do not update my 15 second and 30 second power correctly. I can see in the sprints and KOMs section that I hit 8.9wkg for 15.520 seconds, however the results screen is showing my wkg as 5.8 for 15 seconds. This has been happening for most of my rides. How do I get the correct wkg showing in ZwiftPower?
This is caused when you save your ride activity as Private. You will see that since the end of December in ZwiftPower you see a green bolt on each results line. The green bolt indicates only Live data is being used. The Blue bolt shown prior to 28th December indicates that the initial Live data has subsequently been updated with the more accurate .Fit file data.
Live data is generally accurate for the 20 min and 5 min durations but not accurate for the 30, 15 & 5 second power durations.
Start saving your ride activity as Public and this will resolve your sprint power information (probably only going forwards)
Aaaah thanks Ian that makes sense now, yes I did change my activities to Private. Thank you for explaining and I will change my activities back to Public. Thanks for your help! Cheers Sil
