I do not seem to be able to register any times on segments in ZwiftPower.
I did the TTT up the Alpe 30th December (ZwiftPower - Login) and the rider before and the rider after me appear in the “Sprints & KOM” tab but I am filtered out. (2nd in Latte class)
If I go to the segment tab and select “Watopia” and “Me” I have no segments recorded at all.
Zwift profile is open, as is strava.
Is there at least an explanation for this if not a solution? Thanks
Yeah segments as a whole are a bit of a mess on ZP.
@James_Zwift@xflintx is there anything in the works to look at segments? Sorting results by segment time also doesn’t work most of the time (unless you hack it in to a points race).
Firstly, sorry for bring up an old thread from the dead.
Given that unless an event organiser knows to set the distance beyond the end to work around this, would it not be better to alter the ZP segments to be ~1m smaller/larger. It wouldn’t affect historical timings in a huge way.
