Hello. I am having difficulty in that Zwift won’t upload to Strava. It is connected via the website. Everything else works but when I try to save the ride it is missing the Save + Strava. I’ve closed the ZWIFT app, removed it, started again but nothing works. Screen shot provided. Any suggestions?
Well that’s not supposed to happen ![]()
Even on your Strava account your Zwift ride isn’t showing? When the STRAVA logo is in white text like that, it means your ride should be uploaded there.
If your ride showed up on your Dashboard at least, you can upload your local .fit file straight to STRAVA. Here’s a quick guide on how to do just that: https://support.zwift.com/en_us/can-i-upload-my-.fit-fileactivity-to-a-third-party-site-BkWegRkWSm
Hi, I had the same issue for a few times now.
It seems I have the issue when I join a group ride/race in the companion app. Most of the time, 10 min before the start of the race, I do a warmup in watopia and 2 min before the start of the ride I click the join button on the left bottom side. I ride the race and after the finish Zwift asks to continue the curent ride or to go back to Watopia. I go back to Watopia and end my ride there. At that time I have 3 rides on my Zwift account: The warmup in Watopia, the race and back to Watopia where I end my session. I have the feeling that this causes syncing issues to Strava. When I only ride a race/group ride without joining other worlds, I don’t have the issue.
Sounds familiar?
My rides will not upload to strava or garmin connect. All solo rides and only one ride per day.
for me its strava,connect and also Trainingpeaks that suddenly doesnt sync ![]()
This is happening again since the last update (the one that introduced Drop Shop).
same here
Same problem here
further did I have the following. File did upload to trainingpeaks yesterday but not to strava. today had two rides in a row, first did upload to training peaks, but again not to strava. the second one did not load to both.
Macbook Pro
Same here since the latest update (IOS). Couple more bugs: Had to change the language back (from French to German) - „quit event“ button is still french; started Zwift, joined a group ride and had a powerup in the Companion App (and of course none in Zwift).
your’e right, did not check the bugs on iPad in parallel, but yes, same here. this time development was a bit too agile it seems
Rides not uploading to Strava since the last update for me, either.
Vincent, this is not only Zwift to Strava problem. Check other posts about sync broken from Zwift to Garmin.
Please treat these sync issues as high priority, most of us are collecting stats through 3rd party like Strava or Garmin…
Me too, I uploaded a ride on Sunday from Zwift to Strava, but have completed an event this evening. - 3 rides altogether- and nothing.
The rides are showing on Zwiftpower, is there anyway I can push them through to Strava?
Riding since Dec, had never problems with upload to Strava & TP.
Last Sunday both uploaded; yesterday TP ok / Strava no upload; today TP upload after approx. 1 hour / Strava no upload.
Everything up to date, Zwift running on Win 10 PC, connections ZCA Bluetooth - no changes on my side in the last time.
Found some “…inProgress…” log file on PC - seems like Zwift does not finish properly?
Same here, ride did not save to Strava today. Have not had this before, I’m one for two since the latest update.
It’s happened to me again this evening - Having to manually upload to Garmin so it then syncs to Strava.
Happening with me too - sort it out Zwift!
I’m glad I found this Forum. Been trying to find out why my Zwift rides were not downloading to Strava. Thought I pressed the wrong button yesterday, but the ride showed up in my Zwift profile, so I did a manual upload from Strava to add my ride. Did a ride today and same thing. The only thing different was download the new “Drop Shop” upgrade. Any ideas of what to do next? I use an iPad for my rides, and it usually auto uploads to Strava. Could it be an Apple thing?
Experiencing the same problem here, both on OSX and iOS, for the last 36hrs at least.
