Zwift shifter is not connecting to my wahoo kickr
I installed the zwift cog on my wahoo kickr but my shifter does not work I keep getting this message. But normally my trainer is compatible.
Can someone help me?
Which Kickr do you have?
https://support.wahoofitness.com/hc/en-us/articles/4407140982674-Identify-a-KICKR-trainer
Only the Kickr V6, Kickr MOVE, and Kickr Core support virtual shifting. Perhaps you have something older but make sure the firmware is up to date.
I have the v5
Not supported, send back the click and cog if you can.
@Mike_Rowe1 is it possible that the v5 will be compatibel in the future?
Wahoo has said it is not capable of running the firmware required.
according to Wahoo, no, there isn’t enough memory onboard to update the firmware…
there is a workaround using the qdomyos app @Roberto_Viola can help you
