Thanks again, Paul.
I ran my log file through Zwiftalizer as you suggested and I don’t see anything of concern. In particular, there were no Bluetooth disconnects or resends. Nor were there any other issues related to connections.
Zwift support has suggested I try a “hard reset” of my device, which I’ll do in the next day or so before my next ride.
Kenny
I’ve got the same exact problem. Did it ever get solved?
So I bought a new kickr frame (already had the Core 2 and cog) and very first ride in started skipping gears about 50 mins in. A little bit of online searching and I saw a solution that said to connect the ride controllers to the core 2 via the Wahoo app. I was skeptical because Ive been using the play controllers for a while now and they are connected to the pc (windows 11, i9, gtx5090 - yes its overkill) and Ive never had an issue with them, but I tried it and it worked. 80km in, four separate rides, rock solid, no gear skipping. So must of been BT connection to the pc at fault.
Sorry I didn’t see this question.
NO. I never got it fixed. I ended up using an old iPad for Zwift and stopped using my Mac completely. It works fine on the iPad but the Mac never worked right. Ever.
I was trying to use an Mac and not a PC. It might have been a BT issue.
I stopped trying to use the Mac entirely. I repurposed an old iPad and mounted it to my Zwift Ride frame and it works reliably.
Thanks for the suggestion anyway.
