Zwift Ride Problem
Hello, last week i got my lovely Zwift Ride Frame and got i Problem with the Erg Mode on my Elite Direto XR Trainer. (Testet with Zwift,Rouvy,mywoosh. Its calibrated and got the newest firmware.
I cant go deeper than 120w with the Ride Frame. (Only under 80Rpm)
150w and higher works great in erg mode.
Elite Support told me, its cause of the big Chainring in the Front and the small one from the cog.
With my Gravelbike: 34T Front and and a bigger ring in the back with like 35t it works great. Warumup 70w,80w,90w,100w with erg mode.
Can i buy i bigger singlespeed Chainring for the cog and another chain? Which chain i need?
Replace the Elite Direto XR ist too expensive😀 Thank you all!
While in game, did you go into hardware settings and change the chain ring?
The chain is a KMC Z1 (narrow version, 3/32" - not the wide version)
You could replace the cog with a single speed conversion kit with a larger cog, but I think you will struggle to find anything as big as 35t. For example this one offers 22t: Amazon.com : Bibike Single Speed Conversion Kit 13T/14T/15T/16T/17T/18T/20T/22T Single Speed Cassette & Spacers : Sports & Outdoors
The single speed conversion kit will also need to be designed for 3/32" chains. Avoid the ones that require an 1/8" chain.
I Tried now my 19z from my shimano 2x11.
I can get low to 80w. That low enough for my warmup. (Knee sugerie)
I will try 19z singlespeed
