Zwift Ride left controller failing to update to firmware 1.2
Hi team,
Yesterday, the Zwift app (v1.85) could not connect to the Zwift Ride controllers, which usually does not happen. These controllers are usually the first device detected by the app and have worked without issue so far. I discovered after the ride, that there is a firmware update from 1.0 to 1.2 for these controllers, and proceeded to run it.
The update took 15 mins and only 1 controller, the right side, moved to 1.2 with the app saying: 100% Complete. The left controller is stuck on 1.0. I re-did the attempt 3 times, using a different mobile device (phone the first time, tablet the second and third). I also disconnected and attempted to restart the Zwift Ride controllers 24 hours later. The left side controller appears to start the update process, going to orange color first then blinking blue, but then gets stuck. The app is also indefinitely stuck during that process to “Setting DFU mode”.
Help please.
Nick
Hi @VirtualNico, welcome back to the forums! I’m Jose from Zwift. Thanks for the picture you shared!
I’m glad you stopped by. I wanted to sorry for the delay in getting back to you. I found the ticket you sent in via email, and it looks like one of my support teammates is already helping out, which is great news!
To keep everything moving smoothly, just reply to the email we sent you, and we’ll make sure you’re all set. Let us know if you need anything else, we’re here for you!
Thank you Jose. I have not received an answer from Support yet. Can you please double check which email address this went to?
