Hi all. I bought the Zwift Play controllers a few weeks ago and apart from an occasional lack of response to some button presses in game, they have worked pretty well. Yesterday I was informed there was a firmware update available via the Companion app and attempted to install it, as I have done a couple of times previously.
Both LED’s turned solid yellow and remained like that. The firmware update failed to install.
After six hours, and multiple attempts to resolve the issue I hard reset both controllers by holding down the power buttons for 30+ seconds. The LED’s switched off but I could not switch the controllers back on. They appear to be ‘dead’. I’ve had them both on charge overnight so battery level shouldn’t be a factor.
Is anyone aware of a keypress sequence that is required following a hard reset or are my controllers bricked? Or am I missing something really obvious?
TIA guys,
Exactly the same thing happened to me. Both controllers totally dead after a hard reset following an unsuccessful firmware update. Waiting for Zwift support to get back to me again,
Tried that, but just keep getting the automated responses. Is there a support email address or is ‘chat’ the only option?
Interesting, and glad it’s not just me! Let’s see if theres’ a ‘fix’ that doesn’t involve having to return them!
Keep going through the automated responses and saying it doesn’t help, and eventually you’ll get to an option to contact support.
You can message them somewhere on there. I’ve got new controllers being sent out now, the bricks are going back…
Thanks @Steve_Hammatt Really appreciate that. Thought I was missing something.
That’s good to know @Fraser_Law_KVC Thanks! Hopefully my issue will end up getting resolved the same way!
Hopefully the new ones don’t suffer the same fate as the originals…
Has anyone who had this happen been able to get a response from Zwift support? I’ve tried “that didn’t help” option in the Support hub and nothing happens when I finally get the option to contact them.
I’m reviving this thread. I have the same problem - The right controller firmware update failed, the yellow light stayed on, I forced it off with a 30 second power button push, and now it appears to be bricked. The left controller is ok.
Was everyone’s solution just to get new controllers, or has some super secret method of getting these things to power on been discovered? I have contacted support and currently waiting for a reply, just thought I’d check here in the meantime.
I have to say I’m not impressed with these so far. They’re brand new (I got them for the virtual shifting) and never even used them in game.
TIA
My experience was that both of them failed but yes, getting them replaced was the solution. Since then, I’ve not had any issues with updating them so I’m guessing it’s production issues for individual controllers that cause the problem.
