Zwift Loop after upgrade
After the last update my Zwift that always worked, now it’s in a loop after clicking on Let’s Go. It initiates communication and returns to the Let’s Go screen again.
Zwfit Version: 1.1.5
Game Version: 1.32.2 (107473)
Please provide more details of your Zwift setup such as:
  • Device you’re running Zwift on and it’s specs (type, brand, specific model, CPU, GPU, RAM, SSD/HDD, WiFi/wired type, ANT+/BLE, Operating System and version)
  • Trainer/smart bike (brand and model)
  • All sensors in use (type, brand, model) and connectivity type (ANT+/BLE)
Also please ensure all devices are running current firmware (check using the manufacturer app), and the operating system on your Zwift device is up to date.
Hi CJ,
    SO: Windows 10 with the latest patches
    CPU: Intel(R) Core™ i7-7600U CPU @ 2.80GHz 2.90 GHz
    RAM: 16,0 GB
    Disk: SSD
    WiFi: Intel(R) Dual Band Wireless-AC 8265 with driver update
    ANT+ Device: Garmin USB
    Dare2Ride Fuego 1.0 with latest firmwares
    Everything always communicated via ANT+ protocol
    Power Source/Cadence: Favero Assioma Duo
    Heart: Garmin
    Controllable: Dare2Ride Smart Trainer
11:30am - I cleaned the temporary files of the browsers and the Zwift folder and the problem continued, but now at the end of the morning I tried to open Zwift again and it worked normally.
11:55am - I tried again and the problem came back when trying to communicate with the Zwift CDN.
Definitely some platform instability.
Returns to the Let’s Go screen. Infinite loop.
My LauncherLog has no errors :
I tried to open it 3 times and it was looped.
[12:23:02 2023-02-02] Launcher: Checking for VerCur Override
[12:23:02 2023-02-02] Launcher: prefs.xml file found.
[12:23:02 2023-02-02] Launcher: Auto Startup is Disabled.
[12:23:02 2023-02-02] Launcher: Launcher Version Number 1.1.5
[12:23:02 2023-02-02] Launcher: Initializing UI Components
[12:23:02 2023-02-02] Launcher: Initializing Tray Components
[12:23:02 2023-02-02] Launcher: Initializing Patcher
[12:23:02 2023-02-02] Launcher: Setting Login URL
[12:23:02 2023-02-02] Launcher: Found Launcher URL.
[12:23:02 2023-02-02] Launcher: Navigating to Login URL
[12:23:02 2023-02-02] Launcher: Starting WebView2 Initialization
[12:23:02 2023-02-02] Launcher: Displaying Main Window.
[12:23:04 2023-02-02] Launcher: WebView2 initialized
[12:23:05 2023-02-02] Launcher: Checking for Internet Connection
[12:23:05 2023-02-02] Launcher: Patcher Update Process Check
[12:23:05 2023-02-02] Patcher: Patcher Version Number: “1.3.0”.
[12:23:05 2023-02-02] Patcher: Local download path set to "C:\Users\e001\Downloads\Zwift".
[12:23:05 2023-02-02] Patcher: Server URL path set to “CDN ADDRESS/gameassets/Zwift_Updates_Root/”.
[12:23:05 2023-02-02] Patcher: Local update path set to “”.
[12:23:05 2023-02-02] Patcher: Kicking download of “Zwift_ver_cur.xml”…
[12:23:05 2023-02-02] Patcher: Kicking download of “Launcher_ver_cur.xml”…
[12:23:05 2023-02-02] Downloader: “Zwift_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:05 2023-02-02] Downloader: “Launcher_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:05 2023-02-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[12:23:05 2023-02-02] Patcher: Fetching version attribute from file: “Zwift_ver_cur.xml”
[12:23:05 2023-02-02] Patcher: Local version is “1.0.107473”.
[12:23:05 2023-02-02] Patcher: Server version is “1.0.107473”.
[12:23:05 2023-02-02] Patcher: Local manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:05 2023-02-02] Patcher: Server manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:05 2023-02-02] Patcher: Server manifest file checksum is “-1124893958”.
[12:23:05 2023-02-02] Patcher: Server ver_cur checksum is “-1577951584”.
[12:23:05 2023-02-02] Patcher: Local Launcher version is “0.0.0”.
[12:23:05 2023-02-02] Patcher: Server Launcher version is “0.0.0”.
[12:23:05 2023-02-02] Patcher: Launcher URL for updating self is “ZWIFT SITE”.
[12:23:05 2023-02-02] Patcher: No update available, deleting temp files…
[12:23:05 2023-02-02] Launcher: Launcher Update Process Check
[12:23:05 2023-02-02] Launcher: Checking for Game Update Availability
[12:23:05 2023-02-02] Launcher: Game Update Not Found
[12:23:15 2023-02-02] Launcher: ZwiftApp.exe is not running.
[12:23:15 2023-02-02] Launcher: Starting Zwift App.
[12:23:16 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:16 2023-02-02] Launcher: prefs.xml file found.
[12:23:16 2023-02-02] Launcher: Found Launcher URL.
[12:23:16 2023-02-02] Launcher: Zwift Window Opened. Checking for Game Update.
[12:23:17 2023-02-02] Launcher: DoUpdateCheck() Called.
[12:23:17 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:17 2023-02-02] Launcher: Starting Update Check.
[12:23:17 2023-02-02] Launcher: prefs.xml file found.
[12:23:17 2023-02-02] Launcher: Checking for internet connection.
[12:23:17 2023-02-02] Patcher: Patcher Version Number: “1.3.0”.
[12:23:17 2023-02-02] Patcher: Local download path set to "C:\Users\e001\Downloads\Zwift".
[12:23:17 2023-02-02] Patcher: Server URL path set to “CDN ADDRESS/gameassets/Zwift_Updates_Root/”.
[12:23:17 2023-02-02] Patcher: Local update path set to “”.
[12:23:17 2023-02-02] Patcher: Kicking download of “Zwift_ver_cur.xml”…
[12:23:17 2023-02-02] Patcher: Kicking download of “Launcher_ver_cur.xml”…
[12:23:17 2023-02-02] Downloader: “Zwift_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:17 2023-02-02] Downloader: “Launcher_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:17 2023-02-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[12:23:17 2023-02-02] Patcher: Fetching version attribute from file: “Zwift_ver_cur.xml”
[12:23:17 2023-02-02] Patcher: Local version is “1.0.107473”.
[12:23:17 2023-02-02] Patcher: Server version is “1.0.107473”.
[12:23:17 2023-02-02] Patcher: Local manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:17 2023-02-02] Patcher: Server manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:17 2023-02-02] Patcher: Server manifest file checksum is “-1124893958”.
[12:23:17 2023-02-02] Patcher: Server ver_cur checksum is “-1577951584”.
[12:23:17 2023-02-02] Patcher: Local Launcher version is “0.0.0”.
[12:23:17 2023-02-02] Patcher: Server Launcher version is “0.0.0”.
[12:23:17 2023-02-02] Patcher: Launcher URL for updating self is “ZWIFT SITE”.
[12:23:17 2023-02-02] Patcher: No update available, deleting temp files…
[12:23:17 2023-02-02] Launcher: Checking Launcher Version.
[12:23:17 2023-02-02] Launcher: Checking for Game Update.
[12:23:17 2023-02-02] Launcher: No Update found.
[12:23:23 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:23 2023-02-02] Launcher: Starting Zwift App.
[12:23:24 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:24 2023-02-02] Launcher: prefs.xml file found.
[12:23:24 2023-02-02] Launcher: Found Launcher URL.
[12:23:24 2023-02-02] Launcher: Zwift Window Opened. Checking for Game Update.
[12:23:25 2023-02-02] Launcher: DoUpdateCheck() Called.
[12:23:25 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:25 2023-02-02] Launcher: Starting Update Check.
[12:23:25 2023-02-02] Launcher: prefs.xml file found.
[12:23:25 2023-02-02] Launcher: Checking for internet connection.
[12:23:25 2023-02-02] Patcher: Patcher Version Number: “1.3.0”.
[12:23:25 2023-02-02] Patcher: Local download path set to "C:\Users\e001\Downloads\Zwift".
[12:23:25 2023-02-02] Patcher: Server URL path set to “CDN ADDRESS/gameassets/Zwift_Updates_Root/”.
[12:23:25 2023-02-02] Patcher: Local update path set to “”.
[12:23:25 2023-02-02] Patcher: Kicking download of “Zwift_ver_cur.xml”…
[12:23:25 2023-02-02] Patcher: Kicking download of “Launcher_ver_cur.xml”…
[12:23:25 2023-02-02] Downloader: “Zwift_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:25 2023-02-02] Downloader: “Launcher_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:25 2023-02-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[12:23:25 2023-02-02] Patcher: Fetching version attribute from file: “Zwift_ver_cur.xml”
[12:23:25 2023-02-02] Patcher: Local version is “1.0.107473”.
[12:23:25 2023-02-02] Patcher: Server version is “1.0.107473”.
[12:23:25 2023-02-02] Patcher: Local manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:25 2023-02-02] Patcher: Server manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:25 2023-02-02] Patcher: Server manifest file checksum is “-1124893958”.
[12:23:25 2023-02-02] Patcher: Server ver_cur checksum is “-1577951584”.
[12:23:25 2023-02-02] Patcher: Local Launcher version is “0.0.0”.
[12:23:25 2023-02-02] Patcher: Server Launcher version is “0.0.0”.
[12:23:25 2023-02-02] Patcher: Launcher URL for updating self is “ZWIFT SITE”.
[12:23:25 2023-02-02] Patcher: No update available, deleting temp files…
[12:23:25 2023-02-02] Launcher: Checking Launcher Version.
[12:23:25 2023-02-02] Launcher: Checking for Game Update.
[12:23:25 2023-02-02] Launcher: No Update found.
[12:23:29 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:29 2023-02-02] Launcher: Starting Zwift App.
[12:23:30 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:30 2023-02-02] Launcher: prefs.xml file found.
[12:23:30 2023-02-02] Launcher: Found Launcher URL.
[12:23:30 2023-02-02] Launcher: Zwift Window Opened. Checking for Game Update.
[12:23:31 2023-02-02] Launcher: DoUpdateCheck() Called.
[12:23:31 2023-02-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[12:23:31 2023-02-02] Launcher: Starting Update Check.
[12:23:31 2023-02-02] Launcher: prefs.xml file found.
[12:23:31 2023-02-02] Launcher: Checking for internet connection.
[12:23:31 2023-02-02] Patcher: Patcher Version Number: “1.3.0”.
[12:23:31 2023-02-02] Patcher: Local download path set to "C:\Users\e001\Downloads\Zwift".
[12:23:31 2023-02-02] Patcher: Server URL path set to “CDN ADDRESS/gameassets/Zwift_Updates_Root/”.
[12:23:31 2023-02-02] Patcher: Local update path set to “”.
[12:23:31 2023-02-02] Patcher: Kicking download of “Zwift_ver_cur.xml”…
[12:23:31 2023-02-02] Patcher: Kicking download of “Launcher_ver_cur.xml”…
[12:23:31 2023-02-02] Downloader: “Zwift_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:31 2023-02-02] Downloader: “Launcher_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[12:23:31 2023-02-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[12:23:31 2023-02-02] Patcher: Fetching version attribute from file: “Zwift_ver_cur.xml”
[12:23:31 2023-02-02] Patcher: Local version is “1.0.107473”.
[12:23:31 2023-02-02] Patcher: Server version is “1.0.107473”.
[12:23:31 2023-02-02] Patcher: Local manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:31 2023-02-02] Patcher: Server manifest is “Zwift_1.0.107473_ed024e8f_manifest.xml”.
[12:23:31 2023-02-02] Patcher: Server manifest file checksum is “-1124893958”.
[12:23:31 2023-02-02] Patcher: Server ver_cur checksum is “-1577951584”.
[12:23:31 2023-02-02] Patcher: Local Launcher version is “0.0.0”.
[12:23:31 2023-02-02] Patcher: Server Launcher version is “0.0.0”.
[12:23:31 2023-02-02] Patcher: Launcher URL for updating self is “ZWIFT SITE”.
[12:23:31 2023-02-02] Patcher: No update available, deleting temp files…
[12:23:31 2023-02-02] Launcher: Checking Launcher Version.
[12:23:31 2023-02-02] Launcher: Checking for Game Update.
[12:23:31 2023-02-02] Launcher: No Update found.
This happened to me once a week or so ago. Did a reboot of the PC and it was fine. It’s been perfect since.
Hi Stuart,
Never happened to me, only after the last update. I’ve restarted the computer and the problem continues.
You can use Zwiftalizer 2.0 and do a ping test to see if you can ping the servers.
Hi Gerrie,
I’m in Brazil and my latency is 220ms.
I emphasize that via Android I am not having any problem using the same internet connection. The problem is specifically in the Windows environment.
After updating the NVIDIA manager responsible for my notebook’s GPU, the problem was solved.
