Not totally sure if the flywheel or the plastic case moved but the flywheel looks kinda crooked and touches the plastic on the right side.
Is there any way to realign the while flywheel on the hub or should I remove / cut off the plastic case?
It’s a V1 Hub from Fall 2021 with the V2 cog on a Zwift ride frame.
