Zwift for Mac not receiving power or cadence data from kickr core
Starting today Zwift (running on a MacBook Pro) does not receive either power or cadence data. Both read zero no matter what I’m doing. This is via Bluetooth and via the companion app. I’ve done all of the following:
Restart Zwift
Restart Laptop
Reinstall Zwift.
Nothing works. At this point, Zwift is completely useless.
What happens when you stop zwift and do a ride in the wahoo app?
I don’t use that. But TrainerRoad works fine.
Since TrainerRoad works I assume the Kickr is fine. It would be a good idea to contact Zwift support rather than relying on the community since they can see things in your log files that we can’t. If it’s paired to any other app aside from Zwift, make sure those apps are terminated or deleted (if only for testing) so you can be certain that it’s not being hijacked by anything else.
Sounds like a good idea. Thanks. TrainerRoad actually does most of their support via forums. I guess I figured Zwift would be the same.
