Zwift doesn't start since latest update
Hi, since the update last week zwift won’t start for me. I can start the launcher, but then the zwift application won’t start but just crashes.
Anyone have similar problems? Any usual ways of working?
What system are you running Zwift on, and what are its specs?
I’m running at a PC, a NUC so it’s somewhat limited GFX.
Intel(R) Core™ i7-7567U CPU @ 3.50GHz 3.50 GHz
32GB RAM
500GB SSD
Windows 10 Pro, 22H2
Hi @Jonathan_Flod_1536
Welcome to the forums! I’m Haziel, part of the Zwift Support team.
I took a look at your logs and noticed that your Zwift Launcher is currently on version 1.1.12, which is a bit outdated. I understand your concern and I recommend following the steps in this article on Resetting the Zwift Launcher; it should help resolve the issue.
If you continue to experience difficulties, don’t hesitate to reach out. We are here to help!
If the launcher update doesn’t resolve it, you should also check if you’re using the latest video driver for the Intel 7th gen integrated graphics (version 31.0.101.2134 as of today)
https://www.intel.com/content/www/us/en/download/776137/intel-7th-10th-gen-processor-graphics-windows.html
Thank you. Tried clearing the cache without any success. Will try the drivers as well.
I’ve cleared the cash restarted the PC many times reinstalled Zwift on a perfectly good Windows PC but nothing will allow it to load since the update therefore unfortunately I’ll have to now flip the training peaks virtual… not a good day for Zwift when updates are creating these problems…
I ended up re-installing Zwift and it worked perfectly for me. Seems it didn’t work for everyone. But it light be different problems of course.
Having same issue, spend more time trying to login than actually using, constant issues, screens not loading correctly task bar always missing, purchased new high spec Laptop and it is worse.
What is the laptop? Can you share the model number (probably on a sticker on the bottom)?
Some things people need to do on new Windows machines include disabling OneDrive sync for the Documents directory, and disable any anti-virus software other than Microsoft Defender.
