Every time I finish a ride, Zwift crashes while saving the ride. The ride is saved and uploaded but the app just hangs on the save screen. Can anyone help with this? I am running the latest version of the app on Windows 11. I’ve reloaded it and tuned off screenshots, but nothing - I do have OneDrive running which I have stopped syncing, but nothing I try works. any help would be appreciated
If you contact support they can check out your log file and possibly give advice.
Which GPU are you using?
Its a ryzen series 7
Does it have more than 8GB RAM? If you’re using AMD integrated graphics then it will steal system memory for the GPU and put you below the minimum recommended amount if you only have 8GB installed.
Hello from 2025 where this is still an issue.
Turning off video screenshots solved the crash on save for me.
