Zwift connection to an Schwinn spin bike
I have a Schwinn spinbike without any electrical connection is there a device I can connect to the pedals such as available on Wahoo fitness ’ wahoo rpm cadence sensor’ . Would this be compatible with Zwift?
If not is there another way to make my spinbike zwift compatible?
Thank you
At a minimum you need a speed sensor to move your avatar within Zwift.
Spin bikes for the most part don’t work very well with Zwift unless you install a pedal based power meter to them.
Definitely the best most accurate way to connect a spin bike to Zwift is power meter pedals. Look up Favero Assioma Unos. Bonus, power meter pedals can also be used on any real bike IRL.
