Zwift Companion 3.60 [July 2024]
Hello Zwifters -
Zwift Companion version 3.60 is available in the Apple App Store or Google Play Store. Please update at your earliest convenience.
iOS
  • Addressed a firmware update issue for Zwift Play controllers.
Android:
  • Fixed a bug causing the map to sometimes not display properly.
  • Additional bug fixes.
UPDATE August 2
Companion version 3.60.1 (Android only)
  • Fixed a bug where the Activity Feed isn’t scrollable.
Do you have questions or issues to report? Let us know below.
Updated to version 3.60.0 on Android Pixel 8, and have found that when in Activities I can scroll down through them swiping up on the screen. However, when I attempt to scroll back up the activities by swiping down, the activities don’t scroll, rather they refresh as if at the top of the list/screen.
+1 to this, it also happens on my Android phone
@shooj any word on a fix for this? Makes the Activities screen unusable. Something accidently broke on the update…
@R_osco_P_Coltrane @Arend_teRaa
Yup - I can reproduce what you’re seeing if I lift my finger off the screen before I scroll back up.
If I keep my finger in contact with the screen - I can swipe down (toward older activites) then change directions to see newer activities. Is this the same for you?
Yes, I can go back an activity or two by keeping my finger in contact with the screen. If I do a quick flick (still keeping contact) then it scrolls for a bit but as soon as I make contact again and try to see newer activities, it refreshes instead.
Thanks for confirming what I observed. The team is looking into it!
Yes, same same. Not very functional lol
Please note that a version 3.60.1 patch (for Android only) has been released. Please update in the Google Play Store.
@R_osco_P_Coltrane @Arend_teRaa FYI
Updated my app and all good now!
Bingo! Thanks @shooj ! That did the trick!
Thanks for the speedy fix.
Is there any fix yet for the ‘set reminder’ issue? This used to work but hasn’t for months now - I select set reminder and the time, set as default but it never ‘saves’ and always returns to not selected. @shooj Help!
Anyone?? @shooj ??
images
of the reminder issue I’m having. Anyone?
this has been broken for years now, not sure it was ever fixed
It used to work! Then just stopped!
I haven’t had any issues with it on iOS 17. I use that feature regularly, however one difference is that I have the add-to-calendar setting enabled.
I think I tried that but didnt help. But for me, I dont want it on my calendar, it shouldnt be a requisite of it working :stuck_out_tongue:
