Hi everyone
I’ve set up my Wahoo KICKR Core trainer with the Zwift Cog, but I’m noticing significant chain vibration (and noise) during use. Is this normal?
I’ve tried troubleshooting by:
- Using both my girlfriend’s bike and mine.
- Testing with both worn and brand-new chains.
Unfortunately, nothing seems to solve the issue. The vibration is quite noticeable, and I’m concerned it’s disturbing my downstairs neighbor.
Here’s a link to a short video showing the chain vibration (apologies for the quality):
www.youtube (DOT) com/shorts/vJZGf36REsw
Has anyone else experienced this with the Zwift Cog, or does anyone have suggestions for resolving it?
Thanks in advance for your help!
/Oliver
Hi, @Oliver_Andersen1 , welcome to Forums! I’m Francisco from Zwift Support.
Sorry about this noise issue. I’m glad to help.
Based on the KICKR you have, which has a firmware version of 1.5.5, it appears that you purchased the Smart Frame, specifically the non-freehub Cog body version.
Please verify the following concerning the Zwift Cog (No Freehub):
- Ensure that Cog V2 is set in index position ‘1’.
- Check that the chain tensioner is clear of the frame in all positions and that the chain is properly centered on the pulley.
- Examine the frame installation to confirm that all adjustable screws are sufficiently tightened.
- Attempt to remove the Zwift Cog and inspect the pawls for any damage.
- Check if the chain sprocket is bent by taking a video from above while rotating it by hand to inspect for any bends. It seems the chain is not keeping the aligned direction straight
