Zwift Click power and connection issues
Hi! I have been using Zwift Click and Cog since early July and have recently started having connection issues. This morning, I experienced power issues.
Here is my setup:
  • Zwift on Apple TV 4k
  • Companion on current-generation iPad
  • Running my connections (Click/Cog, Zwift Hub, Wahoo TRACKR HRM) through Companion
  • iOS, firmware and apps all up-to-date
  • iPad is located about 18” (46cm) from Click
  • I have moved the Apple TV to a couple of different locations to see if it makes a difference, but it doesn’t seem to.
  • Home router is located about 30’ (9m) from where I have my setup.
Symptoms:
  • Occasionally lose connection completely and have to restart my ride to get connected again.
  • Disconnections almost always occur between 10 and 15 minutes into the ride.
  • Today at about 5:30 AM ET, I started a group ride (group C on Tempus Fugit). After the pedal assist stopped the resistance didn’t pick up. I went to my normal gear range (I usually use 17), and was spinning at 100+ RPM at 30-60w. I shifted up to 22 or 23 and suddenly, I got all the resistance. I shifted back down to the 15-17 range and started wildly spinning again with barely any power. I exited the ride and started again with almost identical results.
  • After the second ride failed, I tried to start a third time and noticed that Click was not connecting. I completely rebooted both Zwift and Companion and waited for Click to turn off. I chose to ride the Beach Island Loop this time instead of doing a group ride. In the first 5 minutes or so, I felt some slipping sensations, but they didn’t seem to affect the power output.
Bottom line, I am having Click issues that don’t seem to conform to any of the known issues. Any tips for fixing this situation?
What happens if you pair directly to the Apple TV instead of using Companion? Just pairing the trainer and the Click, nothing else.
By the way since you have a Zwift Hub, you can use it to bridge the HRM to save one Bluetooth connection on the ATV.
I started using Companion because I ran out of ATV connections and still wanted HR data. I didn’t even try just getting the HR data from my watch and skipping the Zwift connection.
I have not tried bridging the HRM on the Zwift Hub. I’ll check out these options.
Thanks!
This seems to be working much better. Not 100% for some reason, but well enough. Thanks!
